Speedo Problem
2 replies to this topic
#1 Baloo
Baloo
  • 87 posts
Posted 12 February 2021 - 06:23 PM
The speedo on my NA has died (intermittently flickers). I've been told that it's probably the ABS ECU and it's a fairy common problem. To correct the issue, does the unit need replacing or can it generally be repaired? If repairable, can anyone recommend a business/individual. If it needs replacing, is the only option souring a 2nd hand part?
Cheers, Steve
#2 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 12 February 2021 - 07:09 PM
Check the wiring loom and plug at the n/s/r wheel, it’s a common problem and usually a broken abs wire on the rear hub. Worth checking that first :thumbsup:
#3 aquilaproejct
aquilaproejct
  • 267 posts
Posted 12 February 2021 - 08:27 PM
You can repair if handy with a Dremel and soldering iron. But it means cutting open a sealed ECU fixing and then attempting to seal the unit back up.
