What Brake Upgrade?
9 replies to this topic
#1 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 26 February 2021 - 08:27 PM
Is there an off the shelf brake upgrade that people use for fast road and track? Bigger/better calipers etc? What calipers are a straight swap?
#2 chris_uk
Posted 26 February 2021 - 08:56 PM
im looking at putting my brake discs back into production, they are a fully floating brake disc rotor & bell. I will probably be looking at it in the next couple months once i have finished some of the ongoing projects
#3 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 26 February 2021 - 09:41 PM
Well proven pad and fluid upgrade options in stock size disc/calipers up to most things before getting serious
Then you have next stage options of ap 4 pot std fit options to fancy floating dics etc etc
#4 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 27 February 2021 - 10:56 AM
People have entered race series with these cars on standard calipers and discs without issue. Just upgrade the pads and fluid
#5 smiley
Posted 27 February 2021 - 11:48 AM
:yeahthat:
Carbon Loraine RC6 pads, and anything from the blue section for fluid.
#6 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 27 February 2021 - 12:44 PM
As above, pads and fluids most significant. There are a few people who have upgraded to a Porsche set-up:
https://sites.google.../07---update-29
#7 piwo
piwo
  • 182 posts
Posted 27 February 2021 - 01:03 PM
https://www.mazdaspe...12322&mode=view
And good pads at rear. Front IT doesn't matter
Edited by piwo, 27 February 2021 - 01:03 PM.
#8 siztenboots
Posted 27 February 2021 - 04:22 PM
leg press machine at the gym
#9 chris_uk
Posted 01 March 2021 - 08:08 PM
True dat,
However, when you get proper brakes like mine which weight next to nothing the gains you get from unsprung mass reduction and rotational inertia make the upgrade far more than just stopping in a straight well.
next time we are out, ill let you have a go in mine and you will see exactly what im talking about :)
#10 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 02 March 2021 - 09:10 AM
I have the EP 4 pots up front and the 2 pot front callipers moved to the rear (you need an adapter plate, also make sure you clean the mating surfaces otherwise your brakes will squeal like piggies) with a small spot calliper for the rear handbrake.  I have the 36/40mm ones of these https://www.elisepar...brake-calipers/ (you can get them without the Lotus branding ;)
Can't fault them, they are on 308mm Ali bells front discs and standard discs at the rear and braking power is immense, plus no fade on track even with really hard use.  After I did the mod, I didn't like the softer pedal which reduced feel, and tried a load of different things (http://www.vx220.org...+bb +conversion) ultimately culminating in changing the master cylinder for one from a Porsche Cayenne http://www.vx220.org...ake +conversion.  You need to have it machined to make it fit, but now it works like a dream  :happy:
