Bonding On Rear Lenses
Posted 25 March 2021 - 12:06 PM
I got myself some new acrylic lenses to freshen up my rear lights as both have a couple of small age related fractures in them.
I took the rear light unit off hoping it’ll be a fairly ‘idiot proof’ job but it doesn’t look that simple. I’ve seen the videos of warning them up to soften the old bonding which looks ok but I think the problem will be bonding the new ones on!
There isn’t a natural place the outer acrylic sits on the main light unit. It’s flush in some sides and recessed slightly on other bits.
It kind of has to be bang on! The main unit bolts onto the car with no adjustment and the acrylic has to sit right on the car or it won’t look right.....
Anyone done this or got any tips? I’m thinking of sticking it on then fitting onto the car gently while the bonding is still wet so if the outer acrylic needs to swivel to look right on the car this can be done before it sets. Just feels a bit messy and clumsy this way so open to pointers from anyone who’s done this before!!
Thanks I’m advance
Posted 25 March 2021 - 01:11 PM
Although I've never done it myself I think I read somewhere that replacement lenses could be positioned accurately by putting them on the light cluster in situ. If using Sikaflex or similar it would be safer to mask the bodywork before attempting, but probably not needed if you use something like this:-
https://www.elise-sh...iiif84snbtst1f4
Posted 25 March 2021 - 07:40 PM
I’d be interested to see if anyone has done this before but maybe the idea of bonding on in situ is best. I guess I could cling film the area up the remove the light unit once set and remove all masking etc.
Thanks for the link
Posted 26 March 2021 - 07:15 PM
Do a forum search on Butyl Tape. Think I got some from EliseParts.
Edited by oblomov, 26 March 2021 - 07:17 PM.
Posted 14 May 2021 - 07:37 AM
I just did all my lenses and noticed the same with with the rear ones. I think it must be age related shape change as last time i did this 5 years ago i had no problems.
Ive always used Loctite SI5980 Black Silicone (Gasket Sealant) to bond the lenses on and its been fine - there is just one part of the rear lense that doesnt naturally sit in place tight in.
I guess ideally you would clamp them in place but dont really have the tools for that so was just a bit more generous with the sealant in that part of the lense and seemed to be fine.
Posted 15 May 2021 - 07:06 AM
Edited by Lee37vernon, 15 May 2021 - 07:06 AM.
Posted 15 May 2021 - 03:14 PM
Maybe the silicone is a good in between! More permanent than the tape yet not as permanent that tough windscreen bond.
Really good idea spacing it out to fit/ line up!! Thanks!!
Posted 15 May 2021 - 09:27 PM
