I was just wondering if it is possible to remove the immobiliser function from the ECU in software. 'Siztenboots', mentioned this is a post some time ago, just wondering has anyone ever done this?
Immobiliser
Started by
menright
, May 01 2021 07:39 PM
4 replies to this topic
Posted 01 May 2021 - 07:39 PM
Posted 01 May 2021 - 10:27 PM
I don’t know of anyone that has done this with the original ECU.
Why would you want to do this anyway?
Posted 08 May 2021 - 11:36 AM
yes it can be done , it is not part of the map
eepromtool_04.exe --in ecu.bin --immo off --out ecu_off.bin
Read in 512bytes
Setting Immobiliser: Off
- Immobiliser Off
- Setting backup pages
- Correcting checksums
- Write Successful
eepromtool_04.py --in ecu_off.bin --status
Read in 512bytes
EEPROM Status:
- Type: ECU_eeprom
- Version: Immo3
- VIN: W0L0xxxxxxxxxxxxx (OPEL / Lotus Type 116)
- SKC: 01256
- Immobiliser: Off
- Checksum: OK
- Size: 512bytes
- Cluster Code: 98 8A 4E AB 77 D2 A2
- P0601 DTC: not set
- Immo ID: AUZ6Z0C0185357
- Softcoding ID: 16701
- Tuner Tag: Not Set
- Flash Programming (successful): 0
- Flash Programming (attempts): 1
Posted 08 May 2021 - 12:34 PM
Also on a 2.2 ?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted 11 May 2021 - 08:15 AM
siztenboots, thanks, just as I thought.
