Cheers everyone,
I have been reading a while ago about deactivating the ABS system. I found several threads and I remember that you have to cut one specific wire to deactivate the ABS.
But now I was searching again and found out that if I cut that wire (from the front left ABS sensor I think) the ABS light will be illuminated all the time.
Is there any way to disable the ABS system without having the light illuminated all the time?
I can't find the threads anymore and I don't remember if I read it here or on some german forum
Thanks for your help!
I can't understand why you'd want to do that ?
By disabling ABS by any means it is not operational, that IS a fault, and should be reported as such.
If you really wanted the light to not work either, you could add a further switch to the light itself to ground the wire to turn the light off. Or use a double pole switch to do both at once.
ABS light on dash is B12, Black/Yellow
Although I've seen other posts that say disabling the FL sensor, doesn't completely disable the ABS system, and it still does some sort of pressure limiting to the rear ?
Whether this is true or not, no idea as never tried on mine yet.. That thread said they need to disable the RR sensor to remove this aspect. In which case, it'd probably make more sense to disable this wheel overall, rather than any others.
