Plastic 'welding'
28 replies to this topic
#1 Ivor
Ivor
  • 2,224 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 27 March 2025 - 05:15 PM
After I don't know how many years I have fixed my cracked sill using baking powder and super glue, have used it on bike fairings a few times so no idea why I hadn't thought of using it on the sill, really surprised at the result, will be interesting to see how long it lasts, till I kneel on it the next time I guess
#2 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
  • Interests:Big baps.
Posted 27 March 2025 - 06:51 PM
What's the process?
#3 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 27 March 2025 - 07:58 PM
What's the process?
I've used the technique a lot.  Lots of vieos on Utoob.  You can use bicarb, powdered metal, cigarette ash, but I've also got a kit with different coloured compounds.  You need a low viscosity superglue for best results.
#4 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 27 March 2025 - 07:59 PM
Larger sill plated help.
#5 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 27 March 2025 - 08:21 PM
What's the process?
Interesting about the low viscosity glue, the stuff I used wasn't great but it worked, it ' balled up' rather than soaked into the baking powder, what make did you use?
Edited by Ivor, 27 March 2025 - 08:41 PM.
#6 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 27 March 2025 - 08:23 PM
What's the process?
Put baking powder/bicarb into the crack, drip super glue onto the powder, add more powder if required, it's some sort of chemical reaction between the powder and the glue, I cut the crack open into a 'V' to make space for the powder
#7 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 27 March 2025 - 08:28 PM
What's the process?
Interesting about the lie viscosity glue, the stuff I used wasn't great but it worked, it ' balled up' rather than soaked into the baking powder, what make did you use?
Vitalbond CA superthin.
#8 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 27 March 2025 - 08:41 PM
What's the process?
Cheers, I'll track some down
#9 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 28 March 2025 - 08:16 AM
Sounds great - have you got some pics of the finished join Ivor?
#10 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 28 March 2025 - 09:11 AM
I have but not sure what to use to post here?
#11 blackoctagon
blackoctagon
  • 213 posts
Posted 28 March 2025 - 10:22 AM
I use https://www.imagebam.com/ and take the URL code from there to paste into my posts.
#12 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 28 March 2025 - 10:39 AM
I'll give that a go , thanks
#13 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 28 March 2025 - 10:42 AM
Here you go, have to ignore the hole I cut to fix the crack from the inside, have now reinforced the plastic welding with fibre glass on the inside , I'd previously tried to repair the crack with fibreglass resin but it did not hold. The crack was on the outer edge of the sill and about 2 ft long, the bond looks really strong but time will tell of course
https://www.imagebam.com/view/ME10N6MU
#14 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
Posted 28 March 2025 - 12:51 PM
#15 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 28 March 2025 - 01:00 PM
Looks good!
#16 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 28 March 2025 - 01:32 PM
So how did you do that ? I'm an image posting newbie, keen to know
#17 oblomov
oblomov
    oblomov
  • 3,885 posts
Posted 28 March 2025 - 07:19 PM
Did you drill a small hole at each end of the crack to stop it spreading further?
#18 Ivor
Ivor
  • 2,224 posts
    and now bees
Posted 28 March 2025 - 07:27 PM
Good point, no
#19 bluesunbeam
bluesunbeam
  • 55 posts
Posted 28 March 2025 - 09:57 PM
Good job Ivor. That method of repair is a new one on me; what the Yanks would call 'redneck engineering' on the Insight forum. I would try it on my sill but the damage is too extensive and will require major surgery in the near future.
                                               Dave C
#20 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 30 March 2025 - 10:08 AM
http://www.vx220.org...ures/?p=1996918
