Gearboxes For An Sc Car
6 replies to this topic
#1 sford
sford
  • 1,459 posts
Posted 01 May 2025 - 01:47 PM
So while I don't know what the issue is currently, I love an excuse to upgrade.
My current SC is running a normal NA F23 gearbox. I am on the lookout for something to replace what I currently have when it breaks.
I am looking to see what was available and this came up on ebay
https://www.ebay.co....:Bk9SR7brgb3RZQ
Looking through old posts I can see the references to codes but not the XX reference above.
What is the general consensus? I don't want to go down the route of the 6 speed box, I've found the F23 to be pretty good. I already have a lightened flywheel and a clutch that has done around 20k miles so probably won't replace those. I will do the slave.
#2 stevieturbo
stevieturbo
  • 125 posts
Posted 01 May 2025 - 08:02 PM
XX is 3.95 same as a n/a VX220, so don't see why it wouldn't be a problem.
What is the issue ?
#3 sford
sford
  • 1,459 posts
Posted 02 May 2025 - 01:09 PM
What is the issue ?
Because my inner child was trying to impress my actual child, I did a couple of 'launches' with him in the passenger seat last year. This year I have had some vibration once the car is warm coming from what I think was the back end. Not rev related but wheel speed related. Thought maybe I had destroyed the cv joint but learning towards the diff bearings maybe. I also had a sticking driver side handbrake. I have changed exhausts and fixed the sticking handbrake; in the last drive couldn't feel any vibrations so hoping that it was something to do with the brake getting too hot.
Also, always looking for ways to improve the car!
#4 stevieturbo
stevieturbo
  • 125 posts
Posted 02 May 2025 - 01:54 PM
The gearboxes are usually fairly robust, a few launches shouldn't post much issue. I've done quite a few on mine
#5 Rosssco
Rosssco
  • 4,185 posts
Posted 12 May 2025 - 12:39 PM
See below which gives the gearbox codes and compatibility.
opel-infos.de
Only thing I recall watching out for is that some variants used a deeper bell housing to account for a DMF (dual mass flywheel), but I'm fairly sure if the alphacode is the same then its a direct match.
#6 sford
sford
  • 1,459 posts
Posted 13 May 2025 - 08:11 AM
opel-infos.de
Thanks for that, really useful.
#7 sford
sford
  • 1,459 posts
Posted 13 May 2025 - 08:13 AM
After going down the route of prepping my spare short driveshaft and jacking the car up to feel for excessive play on one side or the other, then sorting the sticking handbrake on the drives side, the juddering haas gone away. Tom suggested it might be the calliper rubbing and I think he was right.
