Hi
I need your help
I´m helping a friend assembly his Vx220 turbo while my waits for her treatment in a month or so.
Right now I´m a struggeling with electrical wiring which is not my strong side.
and the difference between my modified car and this is quite big.
Also there have been some time since someone was working on this , so there are some memory gaps.
This car is equipt with a charge cooler so I´m trying to figure out how to wire the relay for the chargecooler
and where some other wires are going, also trying to move the relays to the cabin.
So first, I guess this blue wire which is connected to a red/white wire is positive for a pump relay for chargecooler?
Brown wire in bottom of the pcture is ground?
What about the redwire? 12V +? Or also ground?
Is this rear licensplats light?
whats this connector for?
Thank you in advance
Br, Per
