Got some bad news when i took the car to Back on Track; there is a 2mm difference in the length of the offside and nearside wheelbase. Despite this i have been loving the driving experience and have not noticed any strange handling characteristics up to speeds of 110 and the car drives and tracks in a very stable manner. I let my mate John take the car out for a few blasts because he always seems to pick up on anything wrong in a cars performance and he said the car felt very good and seemed to handle predictably and very well. The only time the car felt a bit strange was at higher speeds but i think this was due to a faulty damper that was sent back to Gaz shocks and repaired (very quickly) and though i only did one test run the car was definitely better at higher speeds. Whilst i had the shock off i thought i would check the wheel arch liner fastening points as most seemed to be missing so had to remove the liner for the first time. What i found other than a load of damaged mounting points for the liner was a dented and bent stay and distorted lower mounting point for the stay. I would appreciate any thoughts on what this indicates with regards to possible subframe damage and damage to the upper attachment points and whether this could explain the 2mm difference in the wheelbase. Also any suggestions on where i might find an undamaged stay would be gratefully received. I am going to try and include some pictures of the damaged part and mounting point
Dave C
