Hockey Puck Undertray Jacking Point Mod
6 replies to this topic
#1 NDT
NDT
  • 373 posts
Posted 07 February 2022 - 09:03 PM
I've got the undertray off so I can stick a couple of hockey pucks between it and the chassis for jacking purposes.
I assume you bolt them in using the rearmost outer shear panel bolts - anyone done this?
#2 TFD
TFD
  • 615 posts
Posted 08 February 2022 - 06:10 PM
Ive done this but found out that the pucks are a few mm to flat for a perfect fit. I.o.w. when jacking the undertray would deform. I removed them and placed the alu jackpoints. Fit n forget.
#3 Aerodynamic
Aerodynamic
  • 1,538 posts
Posted 09 February 2022 - 08:15 PM
I have done it too. But dont remember if I just mounted them or if I used another spacer.
Br, Per
#4 NDT
NDT
  • 373 posts
Posted 10 February 2022 - 09:04 AM
thanks gents.
I was thinking about gluing a metal tube into the puck so the bolt load goes into the shear panel rather than crushing the puck too much.
Have got plenty of 2 or 3 mm aluminium around if I need to space it a bit.
#5 Baron Von Scubadaddy
    SC
  • 6,657 posts
Posted 18 February 2022 - 02:29 PM
Did they forget the hockey puck at the factory ???
#6 smiley
  • 10,578 posts
Posted 18 February 2022 - 06:03 PM
The puck adds an unofficial lift point.
From factory should be a good idea though, as less chance off issues on siccor lifts.
#7 Madmitch
Madmitch
  • 567 posts
Posted 20 February 2022 - 11:37 AM
I found a guy in the UK who turned down a hockey puck for me so it fits the cup of my jack exactly, also have a pair which are slotted to fit my axle stands, can't remember where I found them though.  Not exactly what you are looking for but if that sounds helpful then pm me and I'll see if I can find where they came from.
Edited by Madmitch, 20 February 2022 - 11:40 AM.
