For Sale
VX220 Supercharged
Stage 2 Supercharged for sale due to not being used as I now have another car.
I need to clear space in the garage for toys.
Current mileage 110,000, starts and runs perfectly I always keep the battery charged up every month. Took it for a run, every thing working as it should forgot how rapid and engaging they are.
It has a service history to 96k after that time I serviced it, oil changes every 1000 max.
I will MOT on sale.
I had it Stage 2 converted by Joe and Rocky from the VX forum. It has 3” Tullet exhaust and manifold that was quietened by Tullet one exit blanked off so 5db quieter.
Pro alloy charge cooler
Twin fans
Alloy radiator
New LSJ injectors
It runs OBD tuner software I have license and computer for it
I then did a full suspension rebuild refresh all new bolts bushes etc.
Wishbones stripped and painted
Uprights stripped and painted
Nitron NTR40 track spec coilovers
Nitron wishbone bearings
Spitfire toe links
Spitfire subframe base
Quick rack with lowering brackets
All new joints to steering column
Uprated adjustable ARB
All new fag wheel bearings
Front bearings with bolt kit
Front 40mm raised uprights
4 pot calipers to front
2 pot calipers to rear
Handbrake spot calipers
Braided brake lines
Carbon Loraine brake pads
Short shift gear link
New motorsport gear cables
Lots more done too much to mention (all the little bits)
Full Geo and corner weights by Hangar 111
Scroth full harness to driver’s seat with cut outs
Carbon binnacle
Carbon dash plates
Shift lights from Spitfire
Last year I did the front louvre and fog light cut outs and fitted type 116 tow hook.
Little osmosis to the bottom of drivers door, not immaculate, some marks. It was more important for me to have mechanicals spot on than the bodywork which I was going to have resprayed a different colour (KTM orange).
I also have all the original parts that can go with the car as I kept everything so that it could be put back to standard minus the original exhaust.
I dread to think what I have spent on it (don’t tell the wife).
Perfect track car good on the road would be great for the National.
Looking for £13,500 ono
I do have a brand new engine advertised separately
Not sure how to add photos here ad with photos is on Facebook VX220.
Please contact me if you would like me to dm them thank you
