Hi, I have a small coolant leak at the front.
The top hoses are fine, as is the bleed nipple. I noticed that one of the bolts that secures the front undertray to the clam was covered in coolant, but not enough to actually drip.
So my thought was the hose connectors to the hard lines that run to the back.
My question is, is there an easy way to see the pipes join, arch liner out?
thanks
