I am looking for LSJ Camshaft sprockets
or a adress where I could buy them
Posted 24 October 2023 - 06:08 PM
Posted 24 October 2023 - 07:55 PM
Not just use Saab parts ? Or Z22 ? Should be readily available locally in a timing kit.
https://www.rockauto...m sprocket,5722
Rockauto usually cheap enough
Posted 25 October 2023 - 06:53 AM
thanks for the answer
I do have the Saab ones installed with my stage 1 Cams, now I am going to install the Comp Cams stage 2 SC, but ZZP did not supply a data sheet how to degree the cams, they recomendet to use the LSJ sprocket because they have a key way
the datas for "Comp cams Stage 2 blower" would also solve my problem
Posted 25 October 2023 - 05:53 PM
Have you any more info on the cams ? part numbers ? they should be etched into the cams, or on the box etc
FFS, my engine has a pair of Comp Cams in it and whoever built it fitted the inlet cam on the exhaust side, and the exhaust cam on the inlet side.
This is info I found online and saved for the various camshaft data, as it did seem hard to come by.
Posted 26 October 2023 - 10:47 AM
Posted 26 October 2023 - 05:52 PM
@ stevieturbo
thanks for all this information, I did check my cams today, looks like 216/218 Duration @ 0.50 Valve Lift
just don"t know the maximum lift centerlines, would go with 112 - 114
@2-20
I know they would fit, but to my knowlage the Z22SE Sprocket wheels are few degres off, and you loose some power
Posted 26 October 2023 - 05:59 PM
I was under the belief the Saab wheels had no indexing, and relied on bolt/tension to lock.
Hence totally adjustable.
From any pictures I've seen elsewhere, It seems mine has Saab camwheels ( B207 anyway, so you'd kinda expect that )
When I get the clam off soon, I'll be checking cam timing over the winter among other changes needed. I'd be surprised if timing is correct ( despite them in the wrong position ), the engine just seems a bit too lumpy at idle for what are very mild cams.
The lobes would be symmetrical anyway, so other than being bizarre to have done it, shouldn't be a huge deal if timed correctly for their location.
Posted 26 October 2023 - 06:03 PM
@ stevieturbo
@2-20
The 216/218 are clearly listed as 110/112.
You'd need to, be a lot off to "lose power", often changing cam timing has more affect on where it makes power, rather than how much it makes.
As well as driveability, idle, emissions etc
Decent video playing about with some cam timing.
Posted 27 October 2023 - 07:24 PM
@2-20
Posted 27 October 2023 - 07:39 PM
Posted 29 October 2023 - 06:34 PM
I have the : stage 2 SC cams specifically developed by and for ZZPerformance but manufactured by Comp cams
they state to be better than the original comp cams, I don"t know is thrue or not
unfortunaly I build a complete exhaust system at the moment, calculatet and desinged for my specific setup
I also removed the balancer shaft,
and installed harder valve springs
so it will be hard to say how much gain is comming from the cams, to many changes at the time.
Posted 05 November 2023 - 11:07 AM
Posted 05 November 2023 - 03:20 PM
The zzp stage 2 SC cams are equivalent to Compcams NA stage 1 (113200) in term of lobe grinds.
Timing is different and sorted out by ZZP so they won't disclose these figures.
Kind of difficult for anyone to time their cams, if they do not disclose the numbers to anyone buying them ?
Let's face it, there's little black art with cams these days. There are thousands of 4cyl engines out there, and cams will be very similar across different platforms, with similar timing figures.
They're all 4 stroke engines, they all operate the same way, and most modern stuff will have decent and similar airflow behaviours and hence durations and valve events
Even comparing the likes of a Kelford Subaru cam in the 250-260 range, the numbers are within 3-4deg of the most similar duration Comp Cam listed for the Ecotec, and some of those are only different from very slightly lobe centreline timings. So in effect are almost the same really if you wanted to play with the cams themselves.
Hell as said, my engine has the cams fitted in the wrong position, and it still, works well. I'm sure it could be improved on, as I suspect they are not timed correctly, but that's purely down to how it idles, which is nowhere near as smooth as it should be for what are still very mild cams.
Although non sequential injection probably isn't helping a lot either with the crappy AEM ecu.
Posted 05 November 2023 - 04:39 PM
Edited by 2-20, 05 November 2023 - 04:40 PM.
Posted 17 November 2023 - 10:50 PM
Out of my head, as it is some time ago, but the "special ZZP Comp Cams" difference is that they checked the timing of each.
Comp Ecotec grinds were sometimes way off when slotted in with the LSJ/Z22SE fixed sprockets...
(not a problem when you time them correctly with modified or Saab sprockets)
As mentioned here; the ZZP profiles are (used to be) standard Comp Ecotec grinds, but nowadays they send their LSJ cams in a ZZP branded box without any spec sheet...
Edited by Exmantaa, 17 November 2023 - 10:52 PM.
