Fezasus Lenses
12 replies to this topic
#1 oblomov
oblomov
  • 3,874 posts
  • Interests:None
Posted 02 January 2024 - 07:17 PM
I have a pair of these on my headlights  - been on for two or three years, and they have become really badly crazed.  Has anyone else had this problem?
#2 VX Mark
VX Mark
  • 177 posts
Posted 02 January 2024 - 09:44 PM
Yeah same for me, they have also gone really cloudy. I was debating trying to wet and dry them and then re-clear coat them.
#3 Lee37vernon
Lee37vernon
  • 314 posts
Posted 02 January 2024 - 10:43 PM
That'll work fine. I've redone my rears several times like this, 800 wet and dry and 2k clear.
#4 VX Mark
VX Mark
  • 177 posts
Posted 02 January 2024 - 10:53 PM
That's good to hear, I'll get cracking on mine at some point.
#5 stevieturbo
stevieturbo
  • 53 posts
Posted 03 January 2024 - 05:43 PM
I've only just fitted some. Would it be worth a lacquer on them from new ? or a protective clear film ?
#6 Lee37vernon
Lee37vernon
  • 314 posts
Posted 04 January 2024 - 11:58 AM
Probably wouldn't hurt, especially if it lives outside. If it's garaged mostly must be a lot less UV exposure
#7 C8RKH
C8RKH
  • 967 posts
Posted 04 January 2024 - 05:27 PM
Lacquer them then put the PPF on them.
#8 oblomov
oblomov
  • 3,874 posts
  • Interests:None
Posted 04 January 2024 - 07:26 PM
The problem isn't on the surface of the lens, the problem is hairline cracks in the plastic of the lens itself.
#9 Lee37vernon
Lee37vernon
  • 314 posts
Posted 06 January 2024 - 12:12 AM
It will mask it a little I think. my rears had the hairline stress marks, I added a little black into the lacquer and you would never know tbh.
#10 fezzasus
  • 7,720 posts
Posted 04 February 2024 - 03:37 PM
The UV coating should be good for two years, if you have problems before that point then please let me know as this is the minimum expectation from the UV coating supplier. There are other options out there, but they add a lot of haze to the lens from new, so it's a difficult balance to find
#11 number-1
number-1
  • 100 posts
Posted 08 February 2024 - 07:02 PM
Is 2 years a good life expectancy for headlight UV coating? I ask as i need a new set of front lenses but don't fancy sanding back every couple of years.My RSMegane has the OEM headlight lenses with no issues  and shes 17 years old and lives outside
#12 Lee37vernon
Lee37vernon
  • 314 posts
Posted 09 February 2024 - 07:17 PM
I'd have them 2k lacquered. A quick flat with 800 wet and dry and they're perfectly clear once done. Takes a long while for UV to affect it
#13 gertje
gertje
  • 500 posts
Posted 10 February 2024 - 06:57 AM
I wraped them in pttf
Verstuurd vanaf mijn CPH2449 met Tapatalk
