High Performance Oils
21 replies to this topic
#1 clipping_point
clipping_point
  • 4,908 posts
Posted 29 November 2004 - 09:04 AM
Thought I´d structure things in a table (as usual)
#2 clipping_point
clipping_point
  • 4,908 posts
Posted 29 November 2004 - 10:09 AM
More info
#3 Smiler
Smiler
  • 5,352 posts
Posted 29 November 2004 - 11:56 AM
prices? :-)
#4 oilman
oilman
  • 400 posts
Posted 29 November 2004 - 02:57 PM
Well, I supply all of these oils (can supply prices as well) and am curious as to how you come to your ratings as I have to disagree with some of your findings. I would be grateful for an explanation and then I will try to put the list together based on the technical data that I have. Cheers Simon
#5 clipping_point
clipping_point
  • 4,908 posts
Posted 29 November 2004 - 03:08 PM
Well, I know you are the expert and therefore I´ll post the sheet here. Actually I wanted to rate them after what you wrote in the "Cheap mobile" thread.
Motul 300V 5w-40 top product
Motul 300V10w-40 top product
MOTUL 8100 Ester E-tech 0W-40 good product
etc.
#6 clipping_point
clipping_point
  • 4,908 posts
Posted 29 November 2004 - 03:09 PM
Sorry, right click it and save it as a *.xls-file. Otherwise it cant be opened ;)
#7 clipping_point
clipping_point
  • 4,908 posts
Posted 29 November 2004 - 04:31 PM
If you make some adjustments to the table it can be sent to: turtobbe@hotmail.com and I´ll prepare piccys and post! chinky chinky
#8 cicastol
cicastol
  • 423 posts
Posted 29 November 2004 - 05:10 PM
Probably Castrol is not better than motul 8100..... and absolutly not in the same legue as 300V or silkolene!!! ;) Oilman needed for ratings thumbsup
#9 oilman
oilman
  • 400 posts
Posted 30 November 2004 - 02:05 PM
clippingpoint I opened the file but could not read it. If you can email the XL file to me I'll list all the oils that I sell, Castrol, Mobil, Fuchs, Total, Silkolene and Motul and will grade them according to quality. I can also put a litre price excl carriage beside them so that people can see which win on the quality vs price stakes. My address is: sales@opieoils.co.uk Cheers Simon
#10 clipping_point
clipping_point
  • 4,908 posts
Posted 05 December 2004 - 04:01 PM
Found these interesting pages:
Car Maintenace Bible: Oils
Viscosity
Edited by clipping_point, 05 December 2004 - 04:03 PM.
#11 clipping_point
clipping_point
  • 4,908 posts
Posted 05 December 2004 - 09:08 PM
And this one:
More than you want to know about oils....
#12 Joe-Turbo
Joe-Turbo
  • 4,176 posts
Posted 06 December 2004 - 08:28 AM
whats this "red line" stuff what courtney sport do like? Redline Engine 10W40 and Gearbox Oil 75W90 Fully synthetic engine oil, designed to provide the highest degree of protection and cleanliness with the lowest friction. Formulated for maximum wear protection and friction reduction across a wide range of operating conditions as well as the ability to withstand heat. Ideal for all engines its high temperature stability makes it a necessity to properly lubricate a turbocharger or hot running engine. Fully synthetic gearbox oil designed to provide excellent low temperature stability and improved gear protection at higher temperatures and to reduce differential temperatures by 6 to 44 degrees C, with efficiency improvements of between 1 - 5 % Price £18.40 per US quart (0.946 litre)
#13 oilman
oilman
  • 400 posts
Posted 06 December 2004 - 09:10 AM
Redline is an American oil and is an ester based one. They are good oils but a touch on the expensive side compared to European ester based oils. I'm preparing a list to be posted here sometime later this week. Cheers Simon
#14 clipping_point
clipping_point
  • 4,908 posts
Posted 29 December 2004 - 06:03 PM
Found this on SELOC from the oil-guru:
I actually sell Mobil 1 as well and consider it a good product although it does not contain ester, it's a poly alpha olefin synthetic.
Polyalphaolefins (PAO's)
These are the most common synthetic basestocks used in the US and in Europe. In fact, many synthetics on the market use PAO basestocks exclusively. PAO's are also called synthesized hydrocarbons and contain absolutely no wax, metals, sulfur or phosphorous. Viscosity indexes for nearly all PAO's are around 150, and they have extremely low pour points (normally below –40 degrees F).
Although PAO's are also very thermally stable, there are a couple of drawbacks to using PAO basestocks. One drawback to using PAO's is that they are not as oxidatively stable as other synthetics. But, when properly additized, oxidative stability can be achieved.
I'm afraid to say that 95% of the oils branded synthetic out there simply are not. The ones you mention are indeed hydrocracked oils.
“HYDROCRACKED” (HC) or MOLECULARLY CONVERTED (MC) BASESTOCKS
There are many petroleum oils available on the market that are so pure and refined, they can now be passed off as synthetics.
They are not made from true synthetic basestocks (at least not in the way that synthetics have traditionally been defined), but they have so little in common with traditional petroleum basestocks, it is really somewhat silly to classify them as petroleum oils.
Petroleum oil basestocks can be put through a super-extreme refining process called “hydrocracking”. In some cases, as in the case of one particular name-brand "synthetic" oil, these highly refined petroleum basestocks can actually be termed and sold as "synthetic".
It is completely legal for lubricants manufacturers to label these oils as "synthetic".
These are extremely high performance petroleum basestocks, but they are not truly synthetic the way that most people understand the term and will not perform to the same level as a premium synthetic oil like PAO (poly alfa olefins) or Esters.
Hydrocracking involves changing the actual structure of many of the oil basestock molecules by breaking and fragmenting different molecular structures into far more stable ones. This results in a basestock which has far better thermal and oxidative stability as well as a better ability to maintain proper viscosity through a wide temperature range - when compared to a typical petroleum basestock.
Although contaminants are still present, and these are still petroleum basestocks, contamination is minimal and performance characteristics are high. This process also can turn a wider range of crude oil stock into well-performing petroleum lubricant basestocks.
The only true synthetic (ester/pao) oils available that I know of are are:
Mobil1
Silkolene PRO
Motul 300V & 8100
Fuchs
Redline
Amsoil
Royal Purple
The exception to the rule is 0w oils that need to contain synthetics to meet the API's pour point of -35 degC as petroleum oils cannot attain this.
Anything above 0w (i.e. 5w, 10w, 15w etc) can be mineral or hydrocracked as tests can be passed.
Cheers
Simon
http://www.opieoils..../lubricants.htm
#15 Whiteboy
Whiteboy
  • 6,950 posts
Posted 29 December 2004 - 11:02 PM
So which is the best oil to buy? :)
#16 nakajima
nakajima
  • 1,521 posts
Posted 30 December 2004 - 01:05 AM
i used Silcolene in my last car. was a small engine / large turbo / plenty BHP type car so i needed an oil that kept things tip top. i will be using Silcolene on my VX too. it impressed me. thumbsup
#17 clipping_point
clipping_point
  • 4,908 posts
Posted 30 December 2004 - 07:49 AM
Seems Motul 300V or Silkolene PRO with 5W-40 ratings are good ones in order to keep low friction (and high BHP)
#18 oilman
oilman
  • 400 posts
Posted 30 December 2004 - 09:56 AM
Yep,
I agree, the Motul 300V range and the Silkolene Pro S are as good as it gets.
Cheers.
Simon.
#19 oilman
oilman
  • 400 posts
Posted 30 December 2004 - 10:54 AM
Ok, yes I posted the above on SELOC as I work closely with many car Clubs recommending and supplying top quality oils.
Now Christmas is over I will work on the list as promised but in the meantime here are some pointers for those that can get hold of technical data sheets.
There some important numbers to bear in mind when looking at technical data sheets and you should be able to obtain these either by looking at the sheets or asking the oil company for the figures.
COMPARING TECHNICAL SPECIFICATIONS (If you can get hold of them!)
When comparing several oils for use in your vehicle, the most important thing to do is to compare the technical specifications of the same viscosity oils.
This is the only way to objectively determine which oil has the best protection and performance characteristics.
There are some useful specifications you might see on the technical data sheet for any given oil viscosity although many manufacturers do not publish the full story which just confuses the matter as you need to compare the same figures to make a true assessment so you may need to ask!
Kinematic Viscosity @ 100 degrees C
Kinematic Viscosity @ 40 degrees C
Viscosity Index (VI)
Pour Point
Flash Point
High Temperature/High Sheer Viscosity
Comparisons can be difficult without the full picture, but not impossible. Here are some of the specifications which are the most important when looking for the best performing oil.
WHAT DOES EACH SPECIFICATION MEAN?
The most commonly found specs are kinematic viscosity at 100 degrees and 40 degrees C, VI (viscosity index), pour point, flash point, and the HTHS number (high temperature/high shear).
Although this test is not used specifically for classification of the oil as a certain viscosity, it is used for establishing the Viscosity Index of the oil. If the VI Index is listed then you can safely ignore this specification, even though it's on all tech sheets.
Once again this test is really only useful for establishing the viscosity classification of the oil and for determining it's Viscosity Index. If the VI Index is listed then you can safely ignore this specification, even though it's on all tech sheets.
Viscosity Index
An oil's VI rating refers to its ability to maintain a consistent viscosity over a wide temperature range. The higher the VI, the better this ability. I wouldn't purchase an multi-viscosity oil that has a viscosity index below 140. The VI of a good monograde oil should be at least above 100. One thing to keep in mind regarding VI numbers is that they only refer to an oil's ability to maintain consistent viscosity when new. They tell you nothing about how quickly the oil will lose this ability to maintain its viscosity over time.
The fact is, even if an oil has a VI of 180, it may only hold that VI rating for a couple thousand miles and this is extremely important! This is where the HTHS number is very important.
A rule of thumb is that Petroleum oils are much more likely to have declining viscosity indexes than synthetic oils. This is because synthetics require a far lower percentage of VI improvers to boost their VI numbers. VI improvers can break down very quickly. Hence, the less VI improver needed, the less likely an oil's VI will be affected over time.
Most tech sheets list the viscosity index.
Pour Point
The pour point of an oil is a temperature -15 degrees C above the temperature at which an oil shows no movement when its container is inclined for 5 seconds. In simple terms, the pour point is the lowest temperature at which an oil will actually flow. This does not mean that it would easily pump through an engine at this temperature - just that the oil still acts somewhat like a liquid at this temperature.
Keep in mind that in oils where pour point depressants are necessary (generally, petroleum oils), the pour point of the oil will rise slightly every time your oil sees cold temperature weather. This is because those pour point depressant additives are being used up. Synthetic oils do not use pour point depressants, so they will hold a consistent pour point for a much longer period of time.
This spec should be found on every tech sheet. Of course, if the oil is not designed for low temperature operation, this spec is obviously less important. But, if you're looking at the spec sheet for an oil that will see cold temperature operation, the pour point should be on there.
Flash Point
The flash point of an oil is the temperature at which the oil vaporizes enough for the gas to become momentarily flammable in the presence of a small flame. There are other conditions and requirements for this test, but in general it is that an oil reaches its flash point when it begins to significantly vaporize.
In today's modern engines a flash point under 180 degrees C is unacceptable. Look for an oil with a flash point of 200 degrees C if you want the good stuff. A good quality synthetic will be higher than this. If this specification is not available, find another oil.
High-Temperature/High-Shear
This test is a simulation of the shearing effects that would occur within an engine. In fact, it's actually designed to simulate motor oil viscosity in operating crankshaft bearings.
Under high stress conditions where shearing can occur, the VI Improvers (polymers) break down. As they do, the viscosity of the oil decreases. This is what the High Temperature/High Shear test checks for.
The HT/HS test is measured in Centipoise (cP) as the Cold Crank Simulator test is. However, in this case, because you're hoping for the least loss of viscosity with an increase in heat and stress, you want the cP value to remain high.
Each SAE multi-viscosity grade has a specific lower limit for the HT/HS cP value. If a multi-viscosity oil cannot achieve a cP value above that limit, it cannot be classified under that viscosity grade. For instance, according to the SAE specifications, an oil must achieve an HT/HS cP value of 3.7 or higher in order to be classified at the 15w40 viscosity grade. The thinner the oil the lower the number.
So, whether this data appears on a manufacturer's tech spec sheets or not, the company always has the data and it should be available on request.
MEETS OR EXCEEDS ALL REQUIREMENTS
Other companies might list a test specification (standard or non-standard) and then put something like "Meets or Exceeds All Requirements". This can be a cop out unless the oil in question is a specialist "race" oil which is tested on the track (Motul 300V is one of these specialist "race" oils).
Any oil on the market should meet or exceed any standardized requirements, otherwise, it shouldn't be on the market.
A good tip is to look for oils manufactured by companies that are not afraid to publish the results of testing for comparison to other oils.
Be aware that some companies will utilize non-standardized testing procedures so they can provide information which looks impressive but can't be compared to other oils in the industry which is generally unacceptable.
If you want to benchmark oils then here are a few "top" oils that you will find hard to beat and I quote these as a standard to aim at eventhough it's a very high standard to set.
Silkolene PRO S 5w-40
KV 100DegC 14.89
KV 40DDegC 92.35
VI Index 169
Pour -51 DegC
Flash 210 DegC
HTHS 4.07
Motul 300V 5w-40
KV 100DegC 13.80
KV 40DDegC 80.80
VI Index 176
Pour -36 DegC
Flash 216 DegC
HTHS 4.51
Silkolene PRO S 10w-50
KV 100DegC 18.17
KV 40DDegC 116.49
VI Index 174
Pour -33 DegC
Flash 210 DegC
HTHS 5.11
Motul 300V 10w-40
KV 100DegC 14
KV 40DDegC 89.5
VI Index 161
Pour -36 DegC
Flash 226 DegC
HTHS 4.19
Silkolene PRO R 15w-50
KV 100DegC 18.2
KV 40DDegC 130
VI Index 156
Pour -35 DegC
Flash 200 DegC
HTHS 5.23
Motul 300V 15w-50
KV 100DegC 17.8
KV 40DDegC 128.1
VI Index 154
Pour -36 DegC
Flash 215 DegC
HTHS 5.33
Mobil 1 Motorsport 15w-50
KV 100DegC 17.8
KV 40DDegC 128.1
VI Index 154
Pour -36 DegC
Flash 215 DegC
HTHS 5.33
I recently looked at Millers CFS 10w-60 and found the HTHS number dissapointing compared to the oils quoted above as it was 3.7. I had expected it to be similar or better than Silkolene PRO S 10w-50 (5.11).
You should bear in mind when comparing oils that the ones above are race proven oils which are extremely shear stable as they utilise proper synthetics including ester as part of the basestock (not petroleum) and although at the top end of the market for both quality and price are mainly sold through specialist Distributors like my Company.
If I can be of further assistance please don't hesitate to ask.
Cheers
Simon
#20 da_murphster
da_murphster
  • 704 posts
Posted 30 December 2004 - 02:23 PM
Errrmmmmm...........alll getting too in depth for me, can we get a summary?
I was going to use Mobile 1 but if anything else is highly recommended can you recommend it and why, + cost??
