John Noble Motorsport - Chesterfield
8 replies to this topic
#1 Jamie K
Jamie K
  • 307 posts
Posted 11 June 2003 - 07:25 AM
Hi all, Had my VX rolling roaded yesterday (standard minus pre cat) Quoted 145 Bhp @ 5800 rpm 149.7 LbFt @ 4000 rpm Actual 142.5 Bhp @ 5970 rpm 146.3 LbFt @ 4313 rpm Not too shabby I suppose. The figures also showed the air to fuel ratio, my car suffers above 3750 rpm and on full throttle as it funs far too richly :( I am glad I have got a "benchmark" before I have anything done to the car. Current thinking is around Exhaust system, fully mappable management and throttle bodies, if the price is palatable. I'll let you know what I do next Jamie
#2 TheRockstar
TheRockstar
  • 675 posts
Posted 11 June 2003 - 07:30 AM
What was the BHP measure at the wheels? (I assume those figures you've quoted are estimated flywheel figures.... and therefore open to a large amount of debate over accuracy).... I assume he did a coastdown test to calculate the losses in the gearbox? If so did he give you these figures aswell?..... Don't mean to open up a large can of worms here......
#3 paulb
paulb
  • 1,598 posts
  • Interests:Driving, wildlife photography, travel
Posted 11 June 2003 - 07:31 AM
Looks pretty good to me Jamie. Remember that power at the flywheel is always a bit subjective on a RR (only true way to measure power is to whip the engine out and run it on a bench dyno). You're within 2% which is well inside experimental error. From the digging I've done, head flowing and cams could well be a useful addition too. Paul
#4 Jamie K
Jamie K
  • 307 posts
Posted 11 June 2003 - 07:52 AM
Can on the floor. Worms everywhere. ;)
It is a "coastdown figures" calculation. I have not got any seperate coastdown figures although from looking at the screens it did seem to be around 22 - 25 bhp on the "drag" side. (i.e. around 120 @ wheels)
I know that no RR gives a true "dyno" representation, however I wanted some consistency and rather than go from one RR to the next I thought it best to get a benchmark before and then after. I may even get another done for a second opinion !
How is that exhaust sounding Paul ?
Jamie
#5 paulb
paulb
  • 1,598 posts
Posted 11 June 2003 - 07:58 AM
Jamie
Dunno yet. About to leave Cambridge and head to Nottingham. Will post more when I get back this afternoon.
Paul
#6 garyk220
garyk220
  • 3,035 posts
Posted 11 June 2003 - 08:09 AM
I wonder if removing the pre-cat has anything to do with it running a little rich?? Perhaps an induction kit, or removing the restriction in the standard airbox would improve the airflow at higher revs and lean the engine out a little.
I'd be interested to see how the standard ECU copes with induction and exhaust changes though. I'm also sceptical about the benefits of 'chipping' the ECU. Throttle bodies and a programmable management sounds good though :) The QED system for the 2.0 Ecotec looks good for 200PS with this set-up and reprofiled cams. Just a pity they are not doing a kit for the 2.2 :(
#7 Jamie K
Jamie K
  • 307 posts
Posted 11 June 2003 - 08:24 AM
I reckon you could be right on this one Gary
Jamie
#8 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 11 June 2003 - 09:00 AM
Would disconnecting the battery which apparently resets the ECU do anything to the mixture??
#9 TheRockstar
TheRockstar
  • 675 posts
Posted 11 June 2003 - 09:52 AM
Interesting article here : http://www.pumaracin....uk/setup01.htm about the pros and cons of rolling road flywheel figures.....
