The basic functions of the software are;
- graphically display engine sensor data live
- read ECU fault codes & reset the engine warning light
- basic data logging facility
I’m using it with my XDAII Pocket PC, and after a few teething problems with the Bluetooth Manager on my PC, it is working very well (Sinclair from Vital Engineering has written a front end to OBDGauge to replace the limited functionality of the Microsoft Pocket PC BT Manager
Running my XDA from battery power, it can communicate with the device from anywhere within 5 or 6 paces of the car.
OBDGauge displays real time sensor values graphically; throttle position, engine revs, speed, engine load, ignition advance, coolant temp, intake air temp, air flow, O2 sensors and fuel trim. It works really well, and the digital speed display is a useful supplement to the speedo. The fuel trim and O2 sensor data looks pretty useful too, but I’ll need a while to fully understand these
The software also reads ECU fault codes and allows you to reset the engine warning light. Fortunately my car has no fault codes, which is reassuring, but I decided to simulate a problem by disconnecting the AMM. I started the car and let the engine idle for a few minutes 3 times (the ECU needs 3 cycles of engine start-stop to log a fault). The next time I fired up the engine, the warning light was illuminated
The diagnostic menu read the ECU and correctly diagnosed a faulty AMM, displaying the generic code “P0100 Mass or Volume Air Flow Circuit Malfunctionâ€Â. I switched off the engine, reconnected the AMM to the wiring loom and selected the reset warning light button. When I next started the engine, the light was extinguished
Interestingly, the ignition advance had reduced from around 30 degrees to -1 degree, the idle was up at 1100rpm and there was a lot of water/petrol vapour pouring from the exhaust. After a few minutes of idling, the ignition advance began to creep back up and the revs slowly dropped back to normal. Presumably the ECU relearning after running on a fail safe mode.
The software also has the facility to log sensor data to a file, This would be pretty useful for hillclimbs and track days, to review key engine parameters and compare speeds on different runs.
All in all, I’m very happy with the device, and a very big
Most of the functionality of a Tech 2 plus some basic data logging, all for under £200. And the added advantage of never having to go near a Vauxhall dealer again
