Back Left Suspension Creak
5 replies to this topic
#1 snoopstah
snoopstah
  • 3,056 posts
Posted 02 June 2005 - 06:15 AM
Hey guys, Noticed an odd noise coming from the back left of the car yesterday evening (to go with all the other noises that come from various bits of the car!). Sounded like a creaking noise when going over undulations in the road. Stopped to have a look, and when I compress the rear left suspension, it makes a noticeable creaking noise. All the others are fine, just that one that's noisy. I'm sure it wasn't like that a couple of days ago. Interestingly, when I stopped and manually compressed it (pushed down on the car over the back suspension) it creaked through the full range of travel - but after driving it about 100 miles, it now only creaks right at the extremety of travel. Any ideas what is it? Or how expensive it's going to be to fix? :(
#2 M8VXL
M8VXL
  • 925 posts
  • Interests:Having fun! and Living life for today!
Posted 02 June 2005 - 06:33 AM
A new rear shock is around £130 but is easy to fit yourself as Vauxhall will try to charge you another £70 fitting. I have charnged both my rear shocks now and its a different car. Marc
#3 snoopstah
snoopstah
  • 3,056 posts
Posted 02 June 2005 - 07:01 AM
Is that the most likely point of failure? Is it possible/easy to check if it's the shock at fault?
#4 LTW2
LTW2
  • 288 posts
  • Interests:Cars, Karting, F1
Posted 02 June 2005 - 07:07 AM
Could be creaking bushes: CLICKY
#5 Arno
Arno
  • 1,238 posts
Posted 02 June 2005 - 10:22 AM
2 'creak' points: Wishbone bushings.. Spray some water on them. If creak gone, then that's it.. Can't really do much about that one though.. Another is that at the back the rack rod inner balljoints get 'cooked' by the exaust and start to creak as the grease thins and runs out. Usually it's enough to lift the rubber seals, squeeze in some grease, work it around, and close it again. After a little while they go quiet again unless they were damaged. Bye, Arno.
#6 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 02 June 2005 - 10:51 AM
periodically spraying some WD40 all around suspension joints helps a lot... otoh, if you hear a gasping/hissing sound from the shock, it might be a blown one...
Edited by Ricky2772, 02 June 2005 - 10:52 AM.
