Vx Clam Shell Removal Pdf
4 replies to this topic
#1 mart356
mart356
  • 1,552 posts
  • Interests:Playing Music, listening to music, clubbing, going to gigs, cars, design, history, computers, restaurants, Phoenix Nights, travel, canoe/ kyak/ sailing, war, filums, sleeping, working out why girls dont tend to have hobbies.
Posted 21 June 2005 - 12:50 PM
Here goes, I found this while ceaning a work server. Thought I'd lost it for good. Layout by me, words and Pix by Mr. Steve Crisp.
#2 TorBeest
TorBeest
  • 22 posts
Posted 02 February 2006 - 11:28 AM
Great pdf! thumbsup
I'm planning on repainting my entire VX,
Does anyone happen to have any articles on how to remove the bodywork from the doors or some other removal guide?
I already have front clam shell removal (as seen above)
and a back clam shell removal: http://www.vx220.org...&t=5496&hl=rear
#3 Richy
Richy
  • 8,699 posts
Posted 02 February 2006 - 11:32 AM
Great pdf! thumbsup
PM danyeates thumbsup ...He re-built more than most on here.
Or stevecrisp thumbsup
#4 TorBeest
TorBeest
  • 22 posts
Posted 02 February 2006 - 01:09 PM
cheers! chinky chinky
#5 garyk220
garyk220
  • 3,035 posts
Posted 02 February 2006 - 02:06 PM
The doors are easy. You need to remove the complete door and beam from the hinge first - 2 allen bolts accessed from the top and bottom of the hinge (the top bolt has a rubber boot to keep moisture out). The door and fittings are a lot heavier than you imagine, so be careful when removing it... it is possible as a one man job though, as are the front arnd rear clams if you are really careful thumbsup Once you've done this, the door panel simply unbolts from the beam - 3 bolts at the front of the beam (you can see these on the car when the door is open) and 2 bolts at the rear, near the handle and lock mechanism (you'll need to remove the door panels to get access to these, and it might be a tight squeeze getting access with the window glass in place) PS One of the bolts at the rear has been filed down to a few mm thick to clear the glass, so be careful not to round it when removing it!!
