Edited by cheeky_chops, 08 July 2003 - 08:30 AM.
Precat Is Gone...
Posted 08 July 2003 - 08:27 AM
Posted 08 July 2003 - 08:52 AM
But I am glad we could all be of service.
Its good isn't it.
Take pics of each stage of the air box removal for the rest of us please.
Enjoy M8
Posted 08 July 2003 - 09:16 AM
Posted 08 July 2003 - 09:33 AM
Edited by cheeky_chops, 08 July 2003 - 09:34 AM.
Posted 08 July 2003 - 09:40 AM
Posted 08 July 2003 - 09:43 AM
I was following that fine until
. Come on whats that all about Never fiddled with a car in my life until I buy my most expensive one and fastest one, and now I feel inclined to take it to bits and make it go faster.I might drop a 25 quid Viper air panel in at the same time...
I take it its all about breathing again!!!!!!
Posted 08 July 2003 - 09:51 AM
And me I'm pretty bad at motor mechanics - took me a day to change discs and pads on a MkII Golf onceNever fiddled with a car in my life until I buy my most expensive one and fastest one, and now I feel inclined to take it to bits and make it go faster.
Re the air filter - the standard ones again slows the air flow and get blocked up. I want a induction kit but its more difficult to fit and alot more expensive (the viper induction is £250rrp - B4D_VX will do you a special price though ) Check out http://www.vx220tuni...performance.asp Mmmm, maybe for Chrismas if im a lucky boy!!
Anyway for £/BHP i think the precat is definately 1st on the list
Edited by cheeky_chops, 08 July 2003 - 09:53 AM.
Posted 08 July 2003 - 10:41 AM
Posted 08 July 2003 - 11:14 AM
'er in doors is also saying that if I want to spend money on the car then I have to put it on my Christmas list. It's such a long way off
iandhd - Pics could/would be handy cheers
N111RAW, cool sig, can I nick it?
Help yourself Thorney. I nicked several frames from your sig as it was! Sos
Posted 08 July 2003 - 11:19 AM
Which in turn I originally nicked from SPeedyHelp yourself Thorney. I nicked several frames from your sig as it was!
Posted 08 July 2003 - 11:25 AM
Posted 08 July 2003 - 11:56 AM
No need to replace with anything. Ok, I don't have a digicam but lets see what I can do on my computer. This is a very poor drawing of the top half of the air box:Do you need to replace the air box/horn with anything?
oh my god that's bad - but gets the idea accross I think.
Posted 08 July 2003 - 12:10 PM
Posted 08 July 2003 - 12:12 PM
How long did it take?
The air horn/box removal not the picture
Posted 08 July 2003 - 12:16 PM
yep - but will assist thanks!!This is a very poor drawing of the top half of the air box:
Posted 08 July 2003 - 12:44 PM
What sort of hole is left when you remove the horn? My very basic fluid dynamics learnin' says that there should be a nice round bell mouth on the the orifice. If it leaves a sharp edged then it can end up more restricted than if the horn were in place. I suppose a bellmouth could be machined out of aluminium and glued in place..................but lets see what I can do on my computer. This is a very poor drawing of the top half of the air box:
A job for this weekend methinks.
Edited by JimH, 08 July 2003 - 12:45 PM.
Posted 08 July 2003 - 01:21 PM
Difficult to say as I spent ages looking for a screwdriver etc... I guess probably about half an hour including getting the wheel off and wheel arch liner. Ideally you should be able to remove the spring clips, remove the pipe that goes to the engine (jubilee clip), take the top half of the box out, remove the horn, then reassemble. However, I also removed both mounting screws that hold the bottom half of the box the the frame of the car which droppped the whole assembly down a couple of inches, making it easier to remove the top half of the box through the wheel arch.How long did it take?
The picture took me about 3 minutes. And yes, I am a designer (well, web designer).
JimH - yes the horn has a rounded bell mouth (oo-er). The hole you're left with is sharper - you may be able to do something with it to improve airflow, not sure. Perhaps make a new shorter horn out of the old one...
And while you're there - make sure the inlet pipe is pointed towards the side vent of the car. Mine was twisted backwards towards the wheel.
Edited by Jase_MK, 08 July 2003 - 01:22 PM.
Posted 08 July 2003 - 02:01 PM
Oops. No offence. Very clear diagram, thank you
Posted 08 July 2003 - 02:10 PM
make sure you jack the car up in the right spot - check for the stickers.cheers Thanks Jase. Might try it tonight then. Just need to find something to lift the car up.
Posted 08 July 2003 - 03:05 PM
