Lightweight Battery
1 reply to this topic
#1 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 15 July 2003 - 10:04 AM
I am about to decide which battery to get, either a motorbike one or those red-top ones.... the 15 should be good.... -6 kg!!
http://www.mdsbatter...uctGroupID=1081
only doubt...the connectors/terminals! :huh: :unsure:
anybody here know what those "m6 male/female" are and if the fit the standard round terminals?
#2 Ricky2772
Ricky2772
  • 3,685 posts
Posted 15 July 2003 - 11:17 AM
heck, just got an answer from them... here it is: Thank you for your enquiry. The Red-Top 15 battery has 5mm threaded terminals and comes with two washers and a wing-nut for each one. These require cables with a flat plate terminal with a 5-6mm hole in them. You may be able to adapt your existing cables to suit these requirements, or a qualified auto-electrician should be able to help. Henry Mitchell
