190 Bhp Westfield For Sale
9 replies to this topic
#1 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 10:28 AM
Hi Guys My first post on here. To get me on my way to getting a vxt I have to sell my westfield I built it myself so will be sad to see it go. Sorry if the detail is a bit too much but i got carried away! £12750 ono or pos part exchange with cash for right vxt I can email pictures if needed. I will post pictures when i find out how? :beat: Contact me on 07966782127 email david@jdboats.co.uk Westfield Seiw 2.0 Zetec Build completed & car SVA’d & registered in Sept 04. Current mileage 3300 Engine 2.0 ltr Zetec Fully rebuilt & up graded prior to installation producing 190 BHP at the wheels Machining work undertaken By Mike Tansky of Fereday engineering. Head Skimmed & valves recut to three point profile. Block skimmed Re bored & new pistons & rings fitted ARP rod bolts fitted New bearings & oil seals all round New piper 275 cams Race line components used for *Shallow wet sump *Water rail & thermostat housing *Lightweight flywheel *Inlet manifold Wunoff silencer polished stainless steel Westfield manifold Ignition & fuel injection Alloy Westfield injection fuel tank High pressure fuel pump Alloy body fuel filter Pressure regulator Jenvey 45mm throttle bodies Bosch injectors 90mm trumpets Piper 600 air filter DTA engine management system Rolling road set up by Mick at Hi tech Gel battery Transmission Type 9 gearbox New prop shaft Ltd slip rear diff New rear wheel bearings Brakes New master cylinder New disks all round Fully reconditioned callipers all round Green stuff pads on front black pads on rear Suspension Alloy avo adjustable dampers with cat motorsport springs Full suspension set up by Pro comp Steering Quick rack with cat motorsport lock stops Racetech removable steering wheel boss with Alpha steering wheel Dash Plays kool contoured dash board with glove recess ETB instruments Key less immobiliser Interior Black carpet set Cobra roadster 7 seats black with yellow piping Willens four point harnesses Westfield alloy gear knob Exterior Powder coated chassis Chrome yellow bodywork with detachable rear wheel arches Black nose cone Fuke motorsport Carbon fibre cycle wings Small headlights & indicators Westfield aero screen with dark smoked upper Carbon effect rear light housings with round crystalight light units Spare wheel carrier with spare mounted on rear 15” TSW 5 spoke alloys with Yoko 539 tyres all round Tonneu cover split between passenger & drivers sides Side doors in same material as cover The list above is fairly comprehensive but if more information is needed I would be glad to fill in the gaps. I built this car myself using mostly new or recondition parts. The main exceptions being the gearbox, rear diff & front wheel bearings all of which after close inspection I could find no reason to change. The gearbox & diff were filled with good quality redline oil & fitted after painting. The car has given me much enjoyment since starting the build through to today. The driving experience is something else when compared to most modern “sportscars”. I shall be sad to see it go but I am ready to move onto my next car. David
#2 Paulbi
Paulbi
  • 179 posts
  • Interests:Sports Cars, Keep Fit, Sports Cars, Power Kiting
Posted 09 August 2005 - 10:44 AM
Hi dave the boat,
Welcome to the forum! ;)
When you come to look around for a VXT I can highly recommend this one http://www.pistonhea...sales/46895.htm
More pictures here > http://www.karmamedia.co.uk/vxt
All the best, thumbsup thumbsup
Paul
07932 780 710
#3 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 11:53 AM
Thanks Paul almost exactly what i had in mind Just need to sell the westy first.
#4 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 12:27 PM
sorry picture link did not work am going to do some work now will try later
Edited by dave the boat, 09 August 2005 - 12:30 PM.
#5 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 04:34 PM
done it pictures at last!
David :jump:
#6 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 04:37 PM
#7 dave the boat
dave the boat
  • 13 posts
Posted 09 August 2005 - 04:55 PM
Last one for a bit. Sorry its a bit big.
#8 dave the boat
dave the boat
  • 13 posts
Posted 11 August 2005 - 10:16 AM
BTT
#9 dave the boat
dave the boat
  • 13 posts
Posted 13 August 2005 - 09:37 AM
Bump
#10 dave the boat
dave the boat
  • 13 posts
Posted 24 August 2005 - 10:35 AM
REDUCED TO £11950 ONO Need to sell soon am missing out on too many good cars.
