Posted 22 September 2005 - 11:33 AM
Posted 22 September 2005 - 11:42 AM
Posted 22 September 2005 - 11:43 AM
Posted 22 September 2005 - 12:04 PM
Posted 22 September 2005 - 12:56 PM
ive got a new vxt only a couple of weeks old have noticed my drivers door has dropped slightly you can hear it when closing the door think ill take it back to the dealer just hope its not going to be in there for days Geoff.Whilst it could well be a hinge issue, check also that the bonding between the outer shell and the rest of the door has not failed.
This happened to me and it led to the rear of the door shearing away from the main part due to the excess stress on the 3 screw mounts: the door shell had to be lifeted up whenever I opened and closed it.
I did get it 'fixed' under warranty but there was a good case I think for a new door.
Worth checking the screws at the back of the door just in case!
Wayne
Posted 22 September 2005 - 01:00 PM
Posted 22 September 2005 - 01:29 PM
Posted 22 September 2005 - 02:10 PM
Posted 22 September 2005 - 03:17 PM
Posted 22 September 2005 - 03:20 PM
Posted 22 September 2005 - 08:39 PM
Posted 23 September 2005 - 01:47 PM
Posted 23 September 2005 - 01:57 PM
Posted 23 September 2005 - 03:03 PM
The drivers door was dropped on my old NA (you had to lift the whole door up to shut it)
and it was a 5 minute job to fix with a 2nd pair of hands:
10mm socket spanner and loosen the 4 bolts holding hinge and door to body, have a 2nd person raise the door as far as it will go (or as far as needed) , tighten bolts and job's done. You may have to lrepeat procedure to fine tune. Also close the door slowly and carefully after adjusting height and check to see the back edge of the door doesn't foul the bodywork.
Posted 18 August 2016 - 05:55 PM
Posted 18 August 2016 - 06:12 PM
Posted 18 August 2016 - 06:15 PM
When you click on someones profile, you can see when they were last online here.
Hint..... almost 7 years ago.
