My Front Speakers, Inc Pics.
67 replies to this topic
#61 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 24 December 2006 - 11:04 AM
If you are lazy someone is flogging these on ebay
http://cgi.ebay.co.u...1QQcmdZViewItem
Just goes againt the grain to spend money when Ive got all the materials here at home. looks as if I will just have to get the tape measure out and graw under the dash.
Thanks Vix hope I do too have a great christmas chinky chinky
#62 CocoPops
CocoPops
  • 17,182 posts
Posted 22 July 2012 - 11:20 AM
Did anyone actually make any templates? I wanna do this ASAP.
#63 techieboy
Posted 22 July 2012 - 11:30 AM
What are you trying to do? This?
If so, I might still have the original MDF mounting "plates" knocking around in the garage somewhere.
#64 CocoPops
CocoPops
  • 17,182 posts
Posted 22 July 2012 - 11:32 AM
Yep that thumbsup
#65 techieboy
Posted 22 July 2012 - 11:41 AM
Will go and have a hunt around after the Flid1.
#66 S5000SC
S5000SC
  • 38 posts
Posted 14 November 2016 - 03:46 PM
I've just finished doing this and it sounds great, easy job, had to patch into the front speaker wires coming from my radio connector cable I just googled to find out what pins they are, to route the cables, below the radio in the dash if you feel about there are other cables passing through to the lower side, so the cables can be pushed through along side another loom cable. To make the mounts I made a template using cardboard and traced it onto the mdf, mounted the speakers tiger sealed the outside edge to bond them into place and screwed the fronts using the holes already there. I did use some dynamat behind the speakers to stop any panel rattle and have also fitted a full carpet kit. I didn't want to hack my dashboard to fit speakers on top in the air vents. So this was the alternative, the hardest bit is getting your head under the dash to the job done got a bit stuck a few times. But well worth it, just take the time to do a good job.
#67 S5000SC
S5000SC
  • 38 posts
Posted 14 November 2016 - 03:49 PM
Worth mentioning the pedal return springs rattle with the new found bass, I cut a cm wide piece of dynamat and wrapped it round the spring and no rattles.
#68 jon_r
jon_r
  • 69 posts
Posted 18 November 2016 - 10:48 AM
I've noticed i've got these in my car though neither was connected up and one speaker has a hole in it. Something to sort over the winter! I wonder if a previous owner of my car has posted in this thread before?!
