Vauxhall Water Ingress Kit
Posted 21 November 2005 - 11:36 AM
Posted 21 November 2005 - 12:02 PM
Nope, the rain-protection-plate developed for the Turbo doesn't fit the NA. But there is a similar plate for the NA available.FAO - you turbo owners!
I have seen that some of you have had a plate fitted that fits to the bootlid to displace any water to the spark plugs/engine.
Does this fit the NA?
I rang vxl Star City and they do not have any parts on the system and are going to ask the workshop for any advice.
Cheers
Chris
Posted 21 November 2005 - 12:15 PM
Posted 21 November 2005 - 12:17 PM
Posted 21 November 2005 - 01:22 PM
Posted 21 November 2005 - 01:36 PM
Vaux told me there was no water ingress fix for the NA other than a slight change to the seals on the coil pack.
Posted 21 November 2005 - 02:15 PM
DETAILS HERE
I WILL MAKE IT FIT
Edited by christurbo, 21 November 2005 - 02:16 PM.
Posted 21 November 2005 - 02:28 PM
Posted 21 November 2005 - 02:32 PM
Edited by LazyDonkey, 21 November 2005 - 02:34 PM.
Posted 21 November 2005 - 07:03 PM
Posted 21 November 2005 - 07:33 PM
Posted 21 November 2005 - 08:18 PM
Posted 21 November 2005 - 09:38 PM
Posted 21 November 2005 - 10:03 PM
Posted 21 November 2005 - 10:38 PM
Eh, well maybe it will - maybe notMartin - just read the PDF.
I cant see a reason why the T water ingress kit cant fit an NA???
LazyDonkey mentioned that the NA engine it (sitting) to high...
Btw the water cover is made out of 1.5 mm aluminium, APPROX. outer dimensions are: L 435 mm x W 195 mm x H 20 mm. I can give you the exact dimensions if you need to do a precise measurement
Edited by Saber, 21 November 2005 - 10:42 PM.
Posted 22 November 2005 - 04:55 AM
Posted 22 November 2005 - 10:13 AM
Posted 22 November 2005 - 02:04 PM
Not sure why you'd fit it? Never seen an NA with water in the spark plugs, they're simply not prone to it....whereas a VXT we serviced yesterday had an inch of water in the plugs
Mine had water in one of the plugs. A few other people have had it too. I will probably just get some silicon out and seal the unit - any reason not too?
Guest_AntB (Guest)
Posted 22 November 2005 - 02:55 PM
that'd be great, i've often pondered the sameIts only £25 so will try and modify it to fit my NA.
Will let you know how it goes.
Posted 22 November 2005 - 03:25 PM
