Throttle Bodies
21 replies to this topic
#1 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 December 2005 - 10:37 PM
On a 2.0L Ecotec I know but looks mmmmm..... special!
Edited by speedster, 05 December 2005 - 10:46 PM.
#2 VIX
VIX
  • 9,497 posts
Posted 05 December 2005 - 10:48 PM
Mmmmm! thumbsup So how are we going to squeeze them in? :blink:
#3 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 December 2005 - 10:49 PM
With mods these engines give 175 ftlb of torque at about 5500 rpm with peak power of 240+bhp at 7750 rpm. :o
#4 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 December 2005 - 10:51 PM
Remove the trumpets and use an intake with an inline filter? And then pull out the ECU and use a MegaSquirt instead :P
Edited by speedster, 05 December 2005 - 10:56 PM.
#5 robfenn
robfenn
  • 1,955 posts
  • Interests:Sports, Photography, Travelling, Racing Cars.
Posted 05 December 2005 - 11:09 PM
I take it the car has a lot of mods though, ITBs themselves won't give that kind of gain! Bet it sounds awesome though, but i'd rather have some nice carbon trumpets me thinks thumbsup
#6 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 December 2005 - 11:21 PM
Here's what QED Motorsport say about it
TB240 Engine
This is a dedicated motorsport engine, and although in general form it is not built for a specific application, variations can be built to suit the regulations of several motorsport disciplines.
The cylinder head is fitted with Q450V profile camshafts with solid cam followers and uprated springs. The inlet and exhaust ports are also reworked and enlarged and our direct to head throttle bodies are fitted to improve gas flow.
To accomodate the higher lift cams, forged pistons are fitted with deeper valve pockets but these also give a higher compression ratio, usually 12:1. Heavy duty con rod bolts are fitted to allow the safe use of higher rpm with rev limits typically set at 8000 rpm. As an additional option, for race applications, a lightweight steel flywheel can also be fitted to make the engine more free revving.
Typically these engines use a baffled wet sump but dry sump systems are also available.
Ignition and fuelling is controlled by a DTAfast ECU which is supplied with a dedicated engine bay wiring loom and all of the relevant sensors.
#7 clipping_point
clipping_point
  • 4,908 posts
Posted 06 December 2005 - 07:36 AM
Looks great. thumbsup However for power I fail to see how separate TB:s can be better than a plenum and single TB. At idle/tickover and low revs separate TB:s will work better, tho, AFAIK.
#8 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 06 December 2005 - 08:06 AM
oi.....stop nicking my pictures. ;) Replace the ali bells with CF, make them a little shorter (but not much), add a diff ECU, non fly by wire throttle, and you're pretty much there with our TB kit. I know I said end Nov launch but you wouldn't want me to launch it until I was 100% happy would you ;)
#9 Smiler
Smiler
  • 5,352 posts
Posted 06 December 2005 - 08:33 AM
3 Q's.. do they have to point straight out ? where's the filtering of the air happening ? does airfolw to the trumpets matter? take it it does.
#10 wrightster
wrightster
  • 2,808 posts
Posted 06 December 2005 - 08:46 AM
yes, there is alos an optimum length for the trumpets depending on applications ..
#11 Thorney
Thorney
  • 11,404 posts
Posted 06 December 2005 - 09:02 AM
yes, optimum length will depend on what you want tyo achieve (torque/bhp etc). They actually point towards the cabin at a 45degree angle. Yes they do have filtering.
#12 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 06 December 2005 - 12:39 PM
opps! sorry John :P didn't know...
Quad CF trumpets exiting through the engine bay lid, would look great B)
Looking forward to the TB kit :D
#13 markv
markv
  • 497 posts
  • Interests:Cars, hoorspelen, computer games, movies, computers.
Posted 06 December 2005 - 06:44 PM
So no more electronic gas pedal? Or did you do some other trick? :)
Mark
#14 ChazUwe
ChazUwe
  • 2,450 posts
  • Interests:Cars, Computers, Drinking and travelling about.
Posted 06 December 2005 - 09:17 PM
Hi John,
What's the latest on the throttle bodies. Any word on costs, likely increases in performance?
Cheers,
Charlie
#15 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 07 December 2005 - 01:19 PM
I guess the Lotus Elise (S2) does not use a Electronic Throttle Body on its motor. Would this mean installation of a cable operated TB in the VX would be relatively easy? :rolleyes:
#16 Thorney
Thorney
  • 11,404 posts
Posted 07 December 2005 - 01:30 PM
We're looking at one main kit but three levels of tune, one for bog stock car (even stock exhaust) - 180bhp bolt on. A stage 2 with full Milltek - 200bhp and a full monty based on a stage 3 car (cams, head, flywheel, Milltek) - £240bhp. The fly by wire is ditched and a throttle cable installed (although there may be other options on this). Sorry its taking so long but I wont release bugger all until I'm 100% happy its perfect thumbsup
#17 coopa
coopa
  • 952 posts
  • Interests:The usual
Posted 07 December 2005 - 01:41 PM
Wow that's cheaper than I thought!
#18 Thorney
Thorney
  • 11,404 posts
Posted 07 December 2005 - 02:04 PM
glol......240bhp thumbsup
#19 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 07 December 2005 - 02:15 PM
:D ho ho ho indeed what a merry christmas! I love those numbers :lol: Suppose it will be in the new year before you get to release full details? In the meantime, estimate, how much of my bonus should I set aside :P
#20 paulf-cam
paulf-cam
  • 1,186 posts
Posted 07 December 2005 - 02:17 PM
B.A.D did it in his supercar (his ECU didn't like drive by wire either) - but he said its very difficult to get it right.
Ta, Paul.
