How To - Disconnect Abs
12 replies to this topic
#1 kev_993
kev_993
  • 3 posts
Posted 27 December 2005 - 10:59 AM
please can anyone tell me how to disconnect the ABS can i take the fuse out? which fuse is it? the reason i want rid of the ABS is because when braking hard from 60MPH the ABS comes on and even when i lift off slightly it still stays on and its really scarry because i over shoot the anticipated stoping point by atleast 20ft!
#2 cicastol
cicastol
  • 423 posts
Posted 27 December 2005 - 11:28 AM
You need to disconnect a front wheel sensor either left or right,if you remove the fuse the tacho doesn't work anymore.
#3 clipping_point
clipping_point
  • 4,908 posts
Posted 27 December 2005 - 12:04 PM
Or make the ABS mod in the DIY section
#4 Robski
Robski
  • 1,905 posts
Posted 27 December 2005 - 01:07 PM
loads of info available on the site.
the search function is your friend :D
#5 kev_993
kev_993
  • 3 posts
Posted 27 December 2005 - 01:21 PM
what do you mean the tacho doesnt work? do you mean the ABS light will light up all the time? or the whole instrument pannel wont work? i dont mind if the ABS light is permantly on as long as it cuts the ABS. thanks everyone for the response!
#6 cicastol
cicastol
  • 423 posts
Posted 27 December 2005 - 04:02 PM
I mean that the tacho doesen't work anymore if you disconnect the ABS fuse,also the engine can stall when you stop running,because the tachometer speed is taken by a rear ABS sensor and the engine ECU take account of the speedo signal for idling motor :o :o
#7 kev_993
kev_993
  • 3 posts
Posted 27 December 2005 - 06:27 PM
right, let me make sure i've got this right in my head before i break something... just read the DIY section on ABS Cut off switch, what i understand from this is that you need to basicly cut that yellow wire to take away ABS and if you want ABS back on you basicly join the wires up again?
#8 clipping_point
clipping_point
  • 4,908 posts
Posted 27 December 2005 - 07:34 PM
Yep! I fitted a swich so I can turn it on/off as I please! thumbsup
#9 JohnyB
JohnyB
  • 667 posts
Posted 28 December 2005 - 09:20 AM
fit the vxr module if you have a shitty one, (like i had - mine had not gone to the recall) night/day diffrence.
#10 ineedtheturbo
ineedtheturbo
  • 1,150 posts
  • Interests:Vx220
Posted 28 December 2005 - 05:12 PM
thumbsup
#11 WazzaVX220
WazzaVX220
  • 306 posts
  • Interests:Great Music, Love, Friends, Holidays, Great Wine, Cars, Beautiful places to drive Cars!!!
Posted 28 December 2005 - 11:01 PM
VXNA and VXTurbo have (crappy) 2-channel ABS system. VXR has proper (and more expensive) 4-channel ABS system, as per S2 elise. Can't see how a VXR module would work better (if at all), but would be happy to learn of a significant improvement for the 2 channel system. Johnny B, please explain!!!!!!!!!!!! Cheers
#12 cicastol
cicastol
  • 423 posts
Posted 29 December 2005 - 12:36 PM
It is a 4 channel ABS not 2 ,only the software is to blame....
#13 JohnyB
JohnyB
  • 667 posts
Posted 30 December 2005 - 10:00 AM
Cheers
first of all i would like to say that i don't have a clue how many channels which module has markv had installed vxr module in his speedster and i folowed his footsteps and did the same.
I had problems with hard pedal and etc.. then i changed to 16/17 wheels and the problem progressed far far more (out of 10 at least 6 failed - pedal hard, .. undriveble car).
I belive that if my car was to be serviced when it should (abs recall) this might not happen when i changed the wheels but it wasnt and ...
Changing the module is a 5 min job couple of screews take the old out, new, drive :)
Compared to what i had before it is magic. It's predictable to say at least.
