Posted 23 January 2006 - 11:36 AM
Posted 23 January 2006 - 12:08 PM
Posted 23 January 2006 - 12:12 PM
Edited by Dave, 23 January 2006 - 12:20 PM.
Posted 23 January 2006 - 04:23 PM
Posted 25 January 2007 - 12:49 AM
Edited by colgy, 25 January 2007 - 12:50 AM.
Posted 25 January 2007 - 09:33 PM
Posted 26 January 2007 - 09:22 AM
Posted 26 January 2007 - 07:19 PM
Cheers, I finally managed to remove the door card using the same method. I kind of figured this would have to be removed as its bloody difficult otherwise. And I get to go through all this fun again in a couple of weeks when I get my replacement handle guardThese should have been the steps to take -
1 remove leather triangle part
2 unclip main foam panel (but do not remove)
3 force out the two plastic screws that hold the door handle guard in place
4 leave the door handle guard in place and rotate the main foam panel
around the door handle guard
5 twist off the door handle guard
6 then remove the door card from the main foam panel ( i used a pair of
cutters and clipped the black plastic clips off)
When i put it back together i first put the main foam panel back onto
the car door then followed by the door handle guard then last of all
replaced the door card back onto the panel.
