Edited by pIMp, 20 March 2006 - 02:47 PM.
Pcm Hack From Hptuners
Started by
pIMp
, Mar 20 2006 02:46 PM
5 replies to this topic
Posted 20 March 2006 - 02:46 PM
http://www.hptuners.com/index.html Has released at beta software. Will this support my speedster? It would realy save me a lot of trouble if it does
Posted 20 March 2006 - 03:34 PM
HP Tuners support forum
I think I read this to indicate not. It isn't entirely clear but I don't think so.
Posted 20 March 2006 - 03:46 PM
The US ECOTEC has a different ECU. It also has a mechanical TB while we have a fly-by-wire TB.
The later american ecotecs, 2005 ->, also has a f-b-w TB though.
Posted 21 March 2006 - 02:05 PM
Is there a way to remap my pcm with bigger injetors and a 2 bar map sensor?(Going FI later on). Using a stand alone EMS means cutting up my standard harness
Posted 21 March 2006 - 02:12 PM
Nope.Is there a way to remap my pcm with bigger injetors and a 2 bar map sensor?(Going FI later on). Using a stand alone EMS means cutting up my standard harness
That part of the PCM hasn't been cracked.
Posted 21 March 2006 - 02:14 PM
No there is nothing out there that allows you to do-it-youself software wise. TMS, AMD, Regal etc. can all hack into the fuelling maps using specialised and expensive software/hardware. I have integrated an Apexi SAFC-2 successfully but the installation means you do have to cut into the harness. Think there are a few owners with MBE ECU's running fueling maps etc. Somebody did mention a MegaSquirt install pendingIs there a way to remap my pcm with bigger injetors and a 2 bar map sensor?(Going FI later on). Using a stand alone EMS means cutting up my standard harness
