Poly Engine Mounts
Posted 30 April 2006 - 07:27 PM
Posted 30 April 2006 - 08:10 PM
Posted 30 April 2006 - 08:11 PM
Posted 01 May 2006 - 07:01 AM
Posted 01 May 2006 - 07:17 AM
Posted 01 May 2006 - 11:53 AM
Posted 01 May 2006 - 12:58 PM
Edited by ian barrett, 01 May 2006 - 12:59 PM.
Posted 01 May 2006 - 07:06 PM
My engine mounts were changed under warranty.also are the engine mounts under warranty
I thought it was the rear sills that were banging about together - sounded like a creaking sound to me.
Surprised to hear that this was the engine mounts - pleased that they were covered by warranty.
Posted 02 May 2006 - 08:18 PM
*groan*also are the engine mounts under warranty or should i just get them & replace them myself. Vauxhall charged me £85 to tell me they could not find the fault without further investigation.
Yes, even without seeing/hearing you car I would say engine mounts 99%
Can I claim my £85 now?
Engine mounts are left and right on the top, front and back on the bottom......both top mounts should be replaced.
Yes its a warranty job. if your car is out of warranty, any mechanic worth his salts can do the job for about £200 all in
Posted 04 May 2006 - 01:04 PM
They are not front and back lower suspension, they are the front and back engine mounts.Those are the wrong ones mateCourtenay have them advertised
They are for the front and back lower suspension mounts.
Its the top (left and right) mounts that go, as mentioned in the Courtenay ad
>clicky<
Yes more vibration is felt when both mounts are changed but there is no reason why just one cannot be uprated for less vibration, but with both uprated mounts there is less forward and backward movement of the engine under acceleration/braking so therefore less strain is transferred to the side engine mounts which fail. To be honest the vibration is minimal really and only felt at certain rpm.
Posted 05 May 2006 - 10:37 AM
Exactly,that is the problem,I've uprated the bottom(front,back) engine mounts with vulcanized rubber,much stiffer than the original but soft enough for vibration dampening,this will save the upper mounts from stress relataed to engine movement.with both uprated mounts there is less forward and backward movement of the engine under acceleration/braking so therefore less strain is transferred to the side engine mounts which fail. To be honest the vibration is minimal really and only felt at certain rpm.
