Fault Codes - What's At Fault Here ?
18 replies to this topic
#1 Mick43
Mick43
  • 3,305 posts
  • Interests:Cars, Bikes, Sport (tennis, squash, gym)
Posted 02 May 2006 - 08:36 PM
My engine light came on this AM.... after a long spell of slow moving traffic...
These are the Scantool codes:
Stored
P0378 Timing Reference High Res Signal B Intermittent / Erratic Pulses
P0420 Catalyst system efficiency below threshold (Bank1)
P0312 Cylinder 12 Misfire detected (this one appeared after I cleared the others ?)
Pending
P0778 Pressure control solenoid B electrical.
Any assistance gratefully recd.. :) thumbsup
Plus only P0420 cleared from system - there was 'clicking' from bonnet when 'clearing' codes - but they wasn't removed.... (although connection tab did report zero codes.. ?)
Edited by Mick43, 02 May 2006 - 08:37 PM.
#2 Robski
Robski
  • 1,905 posts
Posted 02 May 2006 - 08:51 PM
Does the TIS list these? I think it might be useful to start a sticky on fault codes thumbsup
#3 Mick43
Mick43
  • 3,305 posts
Posted 02 May 2006 - 09:00 PM
thanks Robski.... got my ar$e in gear and checked the scantool web site (gendan - it's a very efficient service).. 0378 comes back with wiring problem (ECU/Crankshaft sensor) so will clean these at weekend. 0420 is O2 sensor - so I reckon that just moved out of tolerance. 0778 - no prob causes available... You get just three free look-ups per 7 days so will check 0312 next week if no one knows here... A great idea for a sticky topic on this, ie. fault codes, definitions and fixes thumbsup (we could send the specialists out of business though :rolleyes: PS I've never been able to install TIS - so if someone knows Imnotworthy
Edited by Mick43, 02 May 2006 - 09:01 PM.
#4 Robski
Robski
  • 1,905 posts
Posted 02 May 2006 - 09:25 PM
Cool! thumbsup Not got a copy of the TIS yet but I'm sure someone will be along soon...
#5 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 02 May 2006 - 10:02 PM
[QUOTE]P0778 Pressure control solenoid B electrical.[QUOTE]
Nothing to do with your acc sensor matey????
#6 snoopstah
snoopstah
  • 3,056 posts
Posted 02 May 2006 - 10:38 PM
Any codes that are in the format P0xxx are generic OBD codes, and should be standard across all manufacturers (this is to allow garages to determine faults without having to have a fault code reader for every manufacturer of car that exists).
There's a list of the generic fault code reasons here.
P0312 is an interesting one! You done a conversion we don't know about?! :lol:
P0420 is as said a lambda sensor failure - they do fail quite easily. Simple job to replace them though. Also worth checking the wiring going to the sensor, as it could be caused by a loose connection as well.
P07xx codes are braking and transmission-related I think - not sure more specifically though...
#7 Muncher
Muncher
  • 4,494 posts
Posted 02 May 2006 - 11:16 PM
Interestingly Mick, yesterday I got: P0420 Catalyst system efficiency below threshold Cleared it fine. Did you get any new software with your version of the Scantool?
#8 Mick43
Mick43
  • 3,305 posts
Posted 03 May 2006 - 05:11 PM
Hi Paul I used the SW from the Gendan site... (Scantool supplier..)... I have written to above who are very helpful... they have asked for the fault log to decipher/check/fix codes... thumbsup I'll report back when I know more...
#9 Lps
Lps
    Team 600+
  • 3,375 posts
Posted 03 May 2006 - 08:17 PM
could one of you helful chaps point me at what your using, i may invest in one of these myself (just in case :blink: ) im assuming you run it on a laptop or pocket pc/pda?? what kinda money am i looking at?
#10 Muncher
Muncher
  • 4,494 posts
Posted 03 May 2006 - 09:07 PM
http://www.gendan.co...ct_ELMISOU.html
Mine is slightly different, is serial based and has metal box too.
#11 Mick43
Mick43
  • 3,305 posts
Posted 03 May 2006 - 09:16 PM
Paul... mine is the same as yours... serial port, metal box... LEDs... I guess you are using scantool sw... I will download this as well and compare fault code reading thumbsup
#12 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 03 May 2006 - 09:22 PM
What I use
CLICKY
Comes with Scantools.
#13 Lps
Lps
    Team 600+
  • 3,375 posts
Posted 03 May 2006 - 10:21 PM
What I use
CLICKY
£36 to the UK seems bloody reasonable!
thumbsup
#14 Lps
Lps
    Team 600+
  • 3,375 posts
Posted 03 May 2006 - 10:23 PM
found this on the bay, looks like it has some good free scanning software links that might be worth trying possibly?
scanning software click
#15 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 03 May 2006 - 11:43 PM
Links appear to be from the old Scantools.net site. Here is the up-to-date version.
CLICKY
#16 Mick43
Mick43
  • 3,305 posts
Posted 04 May 2006 - 08:52 AM
I've read fault codes now using Scantool software... and this reports just one faulty code (P0420 - Catalyst limit, which is par for the course... given my mods.) thumbsup So if you purchase use the latter SW package for accurate code reading :) It's really neat being able to interrogate ECU light, and not spend £25 per time at local dealer :D I'll do it for a £5.... thumbsup
#17 Muncher
Muncher
  • 4,494 posts
Posted 04 May 2006 - 09:22 AM
That's good because I'll do it for a tenner, invoice in the post Mick? :P :lol: :lol:
#18 oblomov
oblomov
    oblomov
  • 3,875 posts
  • Interests:Mumblers
Posted 04 May 2006 - 03:12 PM
It's not just me then that's had so much trouble with them. thumbsdown :(
Had to buy a new computer after trying to install them the first time. :beat: Created huge problems including one that no-one was able to sove. :9mm: :(
#19 Mick43
Mick43
  • 3,305 posts
Posted 05 May 2006 - 08:04 AM
Muncher - yep I def owe you a beer or two thumbsup
