Posted 04 May 2006 - 02:29 PM
Posted 04 May 2006 - 02:40 PM
Posted 04 May 2006 - 02:45 PM
Posted 04 May 2006 - 02:46 PM
Do peeps here match the ports up with the manifolds?Full Milltek with CELL 200 CAT + ITG Induction kit + 68mm throttle body + Remap done on an Rolling Road. To get the most out of your head you should also acquire a high flow exhaust manifold!
Posted 04 May 2006 - 02:47 PM
Posted 04 May 2006 - 02:48 PM
Edited by rabidh, 04 May 2006 - 02:51 PM.
Posted 04 May 2006 - 02:56 PM
Posted 04 May 2006 - 03:08 PM
Thats why I will try to make one of my own, I´ve got 16 cm2 ports in my head.....
Posted 04 May 2006 - 03:25 PM
Edited by meldert, 04 May 2006 - 03:27 PM.
Posted 04 May 2006 - 03:39 PM
Edited by rabidh, 04 May 2006 - 03:45 PM.
Posted 04 May 2006 - 04:13 PM
No dude didn't (don't) use 4 tbs he has one large TB into a plenum chamber with trumpets directly to the head...Nice
So Dude used throttle bodies?
Posted 04 May 2006 - 05:53 PM
Posted 04 May 2006 - 06:10 PM
Posted 04 May 2006 - 07:18 PM
Thanks - thats good to know. Shame about the valves, but i'd imagine it would still be a lot better than stock. Are competition valves bigger (so they need new inserts?) or is it just that heat dissipation is better?looks like a courtenay head to me, so hopefully it's the piper cams in it
Posted 04 May 2006 - 09:10 PM
Posted 05 May 2006 - 09:11 AM
Posted 05 May 2006 - 02:21 PM
Well, you could always build your own exhaust manifold...As for the weaponR, I can't really go for hacking my boot around. The VX is my only car, and I need all the boot space there is
I'd also like anything I do to be reversible.
Edited by meldert, 05 May 2006 - 02:23 PM.
Posted 05 May 2006 - 03:36 PM
I have actually started on one myself, it's not finished yet and will be combined with a full custom 2,5" exhaust system.
Posted 05 May 2006 - 04:01 PM
At the moment the exhaust flange is just a blank dummy plate during build up and welding of all the tubes, when that is finished I have a water cut exhaust flange that I vill use. I got that one from Dude, he had a few of them made for his race car. They probably just copied the original or maybe the gasket, I'm not shure...Well, you could always build your own exhaust manifold...
I have actually started on one myself, it's not finished yet and will be combined with a full custom 2,5" exhaust system.![]()
Well done,where did you taken the exhaust flange??
Posted 05 May 2006 - 04:08 PM
