Running Slightly Rough
Posted 11 May 2006 - 10:12 PM
Posted 11 May 2006 - 10:16 PM
Posted 11 May 2006 - 10:18 PM
Posted 12 May 2006 - 08:17 AM
Posted 12 May 2006 - 08:43 AM
Posted 12 May 2006 - 08:56 AM
All modern engines have a MAF (Mass Air Flow meter) so that teh engine knows how much air is coming into teh engine and therefore how much fuel to injectI didn't think the NAs had a MAF...
Second problem is definately accelerator sensor related.
Posted 12 May 2006 - 09:19 AM
Posted 12 May 2006 - 09:54 AM
Posted 12 May 2006 - 10:25 AM
Posted 13 May 2006 - 10:17 PM
Posted 14 May 2006 - 06:24 PM
With vibes at idle its sounds like a fuel or DIS pack problem.My NA with a Regal stage 1 map, precat removed, and Courtenay sports air filter is running a bit rough at idle. The revs vary up and down and it vibrates a lot. It has also had a few problems starting as well, it has started and spluttered and died, then it wouldnt start for a while. It does start in the end, but its a bit of a pain.
AFAIK at idle the throttle pedal sensor is not in play, the ECU is programmed to hold the throttle open a few % on idle. Do check the actual throttlebody pots (2 of) and throttlebody main connector though.
The MAP sensor which all NA use can also be a factor. Its function is to measure air pressure at the intake manifold point. I replaced a faulty MAP a while back - One good indicator of a faulty MAP sensor is high fuel consumption and jerky throttle response. In some cases a faulty MAP sensor appears not to throw a MAP specific DTC, in my case I got an O2 sensor code.
The primary O2 sensor is can also be a culprit as can the crank sensor, but these should throw sensor specific DTC's so your EML will be on.
I had one (crazy) instance where the fuel cut-off switch was faulty. This meant the fuel pump was running intermittenly and therefore fuel pressure was all over the place and the car was running very bad.
Basically outside of Wide Open Throttle there's a bunch of things that the ECU utilises to maintain good fuelling. If your near a dealer they can use their computer systems to run a full sensor and fuel pressure check, sometimes the quickest and cheapest route to the problem.
Edited by speedster, 14 May 2006 - 06:25 PM.
Posted 14 May 2006 - 07:24 PM
It measures intake air pressure not exhaustMost NA engines don't have a MAF/AMM/whatever you want to call it. They use a MAP sensor which measures exhaust pressure (I believe), and are a lot more reliable.
My understanding is that the 2.2 is one of the many that don't have a MAF sensor - hence why you can use induction kits.
Posted 14 May 2006 - 08:50 PM
MAF's or AMM's are a different type of sensor to a MAP senor. The turbo ECU is probably more fussy about the air volume reading hence the use of a AMM whilst the humble NA is happy with simple air intake pressure readings.It measures intake air pressure not exhaustMost NA engines don't have a MAF/AMM/whatever you want to call it. They use a MAP sensor which measures exhaust pressure (I believe), and are a lot more reliable.
My understanding is that the 2.2 is one of the many that don't have a MAF sensor - hence why you can use induction kits.![]()
