Bleeding The Cooling System?
23 replies to this topic
#1 medlow
medlow
  • 258 posts
Posted 27 May 2006 - 03:41 PM
Hello people! I am due to change the original radiator very soon but would like a very quick question answered. After the new rad has been fitted and connected, I will obviously fill back with coolant. Are there any tips that I should know about regarding getting the air out the system?? I ask as the rad is a very long way from the expansion tank and engine so there must be a greater risk of air hiding somewhere..? Is it like any other system, or does extra special care need to be taken when bleeding the system.???? Also, what coolant would you suggest?? Please help. MED.
#2 Muncher
Muncher
  • 4,494 posts
Posted 27 May 2006 - 07:57 PM
When I changed mine I used standard Vauxhall coolant, the price is pretty good compared to standard Halfrods stuff.
#3 cyberman
cyberman
  • 652 posts
Posted 27 May 2006 - 10:00 PM
I had trouble getting all the air out of the system (some is dissolved in the fluid and some in the gas form trapped). Eventually I took the pressure cap off and let it idle till it boiled (well maybe not actually boiled but blew lots out of the inlet) and kept filling it up and then stopped and recapped. This worked wonders. I guess steam was replacing air as it got warm. I believe there is a bleed screw on the rad but I didn't notice it. I expect someone has a more sanitary procedure they will advise but this worked OK.
#4 medlow
medlow
  • 258 posts
Posted 28 May 2006 - 09:13 AM
Thanks Cyberman! thumbsup Any other views on getting air out the system?? I'm wanting to do this before a drive to southern Ireland in 3 weeks. Thanks all! MED.
#5 markv
markv
  • 497 posts
  • Interests:Cars, hoorspelen, computer games, movies, computers.
Posted 28 May 2006 - 10:21 AM
Maybe this one is of some help:
http://www.speedster....., Z20LET).pdf
Mark
#6 JG
JG
  • 13,617 posts
Posted 16 January 2012 - 10:56 AM
Maybe this one is of some help: http://www.speedster....., Z20LET).pdf Mark
I presume from this section:
10. Apply pressure to cooling system 1.0 bar to 1.5 bar
• Use commercially available tool with adaptor KM-471
That KM-471 fits to a std compressor?
#7 CocoPops
CocoPops
  • 17,182 posts
Posted 16 January 2012 - 11:21 AM
Oooh I like that idea, pressurise the system to force the air out thumbsup.
#8 CocoPops
CocoPops
  • 17,182 posts
Posted 16 January 2012 - 11:23 AM
Hmmm, just googled the part number... 69euro.... not quite so good. Perhaps we can make one by modifying an old coolant cap.
#9 JG
JG
  • 13,617 posts
Posted 16 January 2012 - 02:00 PM
i guess thats how it works. got plenty of caps to modfy.
#10 techieboy
Posted 16 January 2012 - 02:13 PM
Just how often are you planning on replacing the coolant? I've never had an issue refilling from empty before. :unsure:
#11 JG
JG
  • 13,617 posts
Posted 16 January 2012 - 02:16 PM
for some reason, from complete empty to complete refill, i'm still not getting circulation. Not driven it on the road yet, that may help.
#12 techieboy
Posted 16 January 2012 - 02:22 PM
That will definitely help. When I replaced the radiator hoses and rad before Le Mans last year, I totally drained the system. On refilling, I puckered up and got familiar with the expansion tank to make sure I got it done in one hit. Worked a treat and the coolant level hasn't budged at all since then. Using the Exige hose with the more accessible bleed valve made life much easier as well.
#13 JG
JG
  • 13,617 posts
Posted 16 January 2012 - 02:26 PM
i think having the water pump out has made quite a big difference, i used to have no problem changing the collant, which i used to do as soon as it lost its nice seethroughness.
#14 techieboy
Posted 16 January 2012 - 02:28 PM
:lol: Tart!
#15 techieboy
Posted 16 January 2012 - 02:29 PM
Though I'm a fine one to speak. Must have had 6 total coolant changes in about 10k miles. :o
#16 JG
JG
  • 13,617 posts
Posted 16 January 2012 - 02:32 PM
I was about to say! :P
#17 Rally
Rally
  • 650 posts
Posted 16 January 2012 - 10:57 PM
By coincidence, I refilled the system on my car today after replacing the rad. After filling it up and using the bleed valves, I started it up but after the engine got hot it was clear that the coolant wasn't going through the rad due to a massive air lock in the top hose. I ended up taking off the little hose from the expansion tank and used it to suck the air out. It did the job but I did then spent five minutes spitting out the taste of coolant. ;)
#18 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 17 January 2012 - 10:34 AM
One tip I was given, was to raise up the rear of the car when bleeding?!
Martin s
#19 TazN
TazN
  • 2,931 posts
Posted 17 January 2012 - 11:15 AM
Martin s
:yeahthat: Seen it suggested in several threads to have the car parked up or down a slope with the end you are using the bleed nipples on to be higher up.
#20 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 17 January 2012 - 01:27 PM
i cant remember how we did mine really, just opened all bleed niples and topped it up, took ages...
