Front Brake Cooling
Posted 30 June 2006 - 08:35 AM
Posted 30 June 2006 - 10:13 AM
Thought I read somewhere that the air flow needs to be to the vanes between the disk faces ie the front edge of the disk not to the disk face itself.The other option was possibly to attach a duct to the hub that would scoop air from the flow under the car and bring it up and round onto the disk face.
Posted 30 June 2006 - 10:45 AM
The other option was possibly to attach a duct to the hub that would scoop air from the flow under the car and bring it up and round onto the disk face.![]()
How about sagaris style vents combined with fog light option with the S2 vent behind the wheel arch?
Dave
Posted 30 June 2006 - 10:47 AM
Edited by Jase_MK, 30 June 2006 - 10:50 AM.
Posted 30 June 2006 - 12:01 PM
If you are going to cut dirty great holes in your cars in order to feed ducting for cool clean air to the brakes, then could I please recommend that you fit them correctly.
I see in the pictures above that Ricky has fed the end of the hoses directly onto the disc face, this is wrong.
The hose should be ran up to the centre of the bell so that the clean air gets pulled into the vanes and cools the discs evenly from the centre out.
By leading the hose onto the inner face you are effectively cooling the disc more on one side than the other, giving an un-even cooling rate.
Gav
All the fog light mod pictures I have seen show the air blowing on one disc face rather than aiming it at the centre. So that suggests the air flow through the disk vanes is from centre ie hub area to outer edge of the disk.
Richard
Posted 30 June 2006 - 09:32 PM
Posted 03 July 2006 - 09:02 AM
Posted 03 July 2006 - 03:08 PM
Cooling vents like these...
Is that a photochop????
Exige spoiler looks ace!
I want one!
Posted 03 July 2006 - 07:01 PM
Posted 03 July 2006 - 09:56 PM
Would it be detrimental to the engine cooling ??
Posted 03 July 2006 - 11:49 PM
Something like these look like they would create a more even flow over the disc, though maybe in a different colour!
Posted 05 July 2006 - 11:31 PM
http://smg.photobuck.../?sc=1&multi=10
he has some blanks to cover the intakes up when not on track
Edited by TarmacTerrorist, 05 July 2006 - 11:58 PM.
Posted 06 July 2006 - 06:28 AM
Surely cooling the disc from only one side could cause warping/distortion of the disc and uneven pad wear
Potentially yes but this would only be the case for solid disks, the AP's/aftermarket are two disks with cooling vanes inside which 'wick' the air though the centre.
Mind you the outer part of the disk gets more air through the wheel so with inner brake ducting its more likely you're just redressing the balance.
Posted 06 July 2006 - 07:48 AM
Posted 10 July 2006 - 03:59 AM
(scroll around the car the press on the wheels)
http://www.saab.com/...en/index2.shtml
