Can Vx Mileage Be Clocked ?
Posted 03 July 2006 - 06:26 PM
Posted 03 July 2006 - 06:33 PM
i was just wondering if the vx can be clocked with the stack display been digital or if it could be done by dealers etc
Any car can be clock if you have the right tools.....
not sure if the VX is anymore prone to it than others....
Edited by adtmits, 03 July 2006 - 06:33 PM.
Posted 03 July 2006 - 06:34 PM
Posted 03 July 2006 - 06:38 PM
Posted 03 July 2006 - 06:39 PM
Posted 03 July 2006 - 06:50 PM
Posted 03 July 2006 - 08:12 PM
yeah i have heard about dealers doing it to reset test delivery mileage
with a vx tho wear is hard to gauge imo seats wear fast with the way you have to get in and out etc
Isn't it as simple as changing the dash?
Ta, Paul.
Posted 03 July 2006 - 08:59 PM
Ta, Paul.
No!
The mileage is stored in EEPROM (electrically erasable programmable read-only memory) memory in the ECU. This means that it's value is allowed to be changed and will still be present even if the ECU is switched off. This is contrast to ROM (Read Only Memory) which means you cannot change its value (e.g. circumference of tyre or pi) and RAM (Random Access Memory) e.g. the coolant temperature - when the ECU is switched off the value is lost. However with EEPROM when you switch the ECU off the data is not lost.
If you knew the memory location of the variable in the ECU then it would be very easy to "reset" it to zero...or start it at any other value you wished up to the maximum that can be stored for that amount of memory.
See! I am an Automotive engineer!!
PS playing with memory locations, changing values in ECUs (Calibration) is what I do......
Posted 03 July 2006 - 09:23 PM
Posted 03 July 2006 - 09:26 PM
Posted 03 July 2006 - 09:52 PM
Posted 03 July 2006 - 10:03 PM
Johnaachen
Your cars a low mileage example isnt it?
Ed![]()
Very!
That did make me laugh!!
@slindborg - no I work for Ricardo......
You need to use somethinng like INCA (if its Bosch software) and then you can access all the parameters in the ECU.....it depends what type of ECU it is though what type of claibration tool you can use....
Posted 03 July 2006 - 10:22 PM
Posted 03 July 2006 - 10:27 PM
It's mind boggling and cool finding out what people do to earn a crust out of niches in life.
John - at least if your odomoeter goes wrong you'll be able to fix it!ducks for cpver.
Swings at dw1 and misses!!
Probably not no!
Posted 03 July 2006 - 10:28 PM
Posted 03 July 2006 - 10:34 PM
My NA is on its 3rd Stack unit the first 2 clicked badly. At each replacement the mileage went back to zero (although I made a point of having the correct mileage noted in the log book). I was told that there was no way for the correct mileage to be picked up by the replacement Stack unit even assuming it is stored in the ECU.
Then the calculation/memory must be made in the stack rather than in the ECU....I stand corrected!
Posted 04 July 2006 - 12:35 AM
Posted 04 July 2006 - 08:54 AM
Posted 04 July 2006 - 09:07 AM
Ahhhhh thats where ricardo are then
I work for the uber stable Visteon in diesel PCMs
Id guess that you might be able to have a crack at the Cluster with the KWP2000 protcol but i doubt it very much as there didnt appear to be a comms line on the wiring diagram when i was wiring a VX cluster into a nova (oh yes lol)
Posted 04 July 2006 - 12:05 PM
Same here... previous owner had the bad clicking problem and had the Stack unit replaced under warrenty. mileage to zero..
Vaux said they cannot clock the unit forward.
Luckily I have the document from Vauxhall stating what the mileage was before it went in for the repair, to avoid any confusion later on..
MED.
