Headlight Beam Adjust
Posted 01 August 2006 - 11:11 AM
Posted 01 August 2006 - 11:14 AM
Posted 01 August 2006 - 11:16 AM
Posted 01 August 2006 - 11:29 AM
Posted 01 August 2006 - 11:35 AM
Posted 01 August 2006 - 01:44 PM
Posted 01 August 2006 - 01:56 PM
Posted 01 August 2006 - 05:09 PM
Posted 03 April 2017 - 06:14 PM
Posted 03 April 2017 - 06:25 PM
How easy is it to replace the headlights start to finish. Just failed mot on beam pattern. Can all lamps be adjusted?
only need to adjust the dipped projector, however it's likely that yours failed because the ball socket has failed.
Posted 03 April 2017 - 09:10 PM
Mine has failed because the beam direction is towards oncoming traffic as if I have a European lamp fitted. Is there a way I can tell from the outside, print on the bottom maybe? It's the outer bulb that's incorrect.only need to adjust the dipped projector, however it's likely that yours failed because the ball socket has failed.How easy is it to replace the headlights start to finish. Just failed mot on beam pattern. Can all lamps be adjusted?
Posted 04 April 2017 - 06:01 AM
You almost certainly won't have a European headlight fitted, however you can tell very easily. Wait until it's dark and park your car in front of a wall or garage and turn the lights on. a UK projector beam pattern will look like this
While a European one will be reversed like this:
You can't simply fit the wrong bulb and change the beam pattern. The headlight projectors are secured to the headlight assembly and they contain a shutter which directs the shape of the beam. The projector mounts will have failed to allow it to point the wrong way (so it's still a UK pattern, but not pointing straight). You'll have to open up and fix
Posted 04 April 2017 - 06:43 AM
Thank you
Hopefully you can see my attached image which shows the O/S kicking up resulting in MOT fail. So you reckon this could be repairable if taken apart? Im guessing it will be pretty obvious once looked at from behind, but to fix, without trying to sound stupid, is this superglue or something?
Posted 04 April 2017 - 06:47 AM
Bizarrely, that does very much look like a european spec headlight. Since it's perfectly aimed I can't see how it has ended up at that pattern.
The good news for you is that the European ones are worth much more than the UK ones.
what's the history of your car, I assume this is the first time you've MOT'ed it?
Edited by fezzasus, 04 April 2017 - 06:48 AM.
Posted 04 April 2017 - 06:56 AM
Correct. I looked at MOT history and it failed on this before I picked up the car, but was then passed again on the same day (mmmm) I was shown that it passed with no advisory's. I found this out yesterday after first mot. On mot history it also failed on this lamp in 2013. I wouldn't have thought there would be too much of a demand for the European ones...
Thanks for your time btw
Posted 04 April 2017 - 07:28 AM
This guy might be about to become your best friend. http://www.vx220.org...n-beam-pattern/
Edited by fezzasus, 04 April 2017 - 07:28 AM.
Posted 04 April 2017 - 12:00 PM
As you can see I have no arrow on the headlamp, however I do have an arrow pointing to the outside of the car on the N/S. Would you agree that this cements I have an European lamp fitted?
Thanks
Posted 04 April 2017 - 03:15 PM
Arrow denotes UK spec lamp, lack of arrow denotes europe spec.
Edited by fezzasus, 04 April 2017 - 03:16 PM.
Posted 04 April 2017 - 05:41 PM
Thank youArrow denotes UK spec lamp, lack of arrow denotes europe spec.
Posted 04 April 2017 - 08:10 PM
Thanks for the link. I read this last night. Correct me if I'm wrong but aren't we after the same thing (UK lamp) or do you mean he might want a spare?This guy might be about to become your best friend. http://www.vx220.org...n-beam-pattern/
