Posted 08 October 2003 - 09:04 AM
Posted 08 October 2003 - 10:13 AM
Posted 08 October 2003 - 10:33 AM
Posted 08 October 2003 - 11:04 AM
Posted 08 October 2003 - 11:24 AM
Posted 08 October 2003 - 12:46 PM
Posted 13 October 2003 - 04:06 AM
Posted 13 October 2003 - 07:46 AM
Posted 16 October 2003 - 11:35 PM
Posted 17 October 2003 - 06:18 AM
Posted 17 October 2003 - 09:14 AM
Posted 17 October 2003 - 06:51 PM
Posted 17 October 2003 - 07:24 PM
Posted 17 October 2003 - 07:28 PM
Posted 17 October 2003 - 08:54 PM
Posted 18 October 2003 - 09:17 AM
AmD's 220bhp map ups the boost a bit and increases fueling to compensate the heat, add the exhaust and the map is changed to take into account better breathing but no 'extra' power is sought as the exhaust provide it already.
Posted 11 November 2003 - 10:39 PM
Hi was just curious is that 1.2 bar to redline?. Looking at the turbo flow maps thats basically the maximum the turbo will give you.Pretty much all in the map. The Sprint has 'only' 240bhp but over 280llb's of torque (well over the GB limit
) boost is still upped to get the torque hence the heat. I'm not sure what boost they're running 1.25 bar? (standard is 0.85bar).
Milltek on its own gave 23-25bhp and the PiperX gave another 10bhp (all at top end though). As the exhaust is sucking heat away the extra bhp (and minor torque) gives a bit more heat but as the gas flow is better its not enough to cause a problem.
The Milltek can only do so much and whilst in real life the engine with one fitted could probably run to 240bhp or more AmD are conscious on logevity and always spec down to safe level rather than be daft.
Adding on the charge cooler allows the 'daddy' map to be used. This ups bhp to 260odd but ups torque to 250llbs' (which is significant) as the coller drops the intake temps by over 13 degrees and as such the map is written to get torque and power and not simply to reduce temperature.
I'm currently running a 'special' - 275llb's of torque and 265bhpAmD have dropped the torque down a bit (early in the range) compared to the Sprint to save the GB but have got it to keep it all the way through the rev range whereas the Sprint tails off (we think due to heat build up). I'm running 1.2bar and the CC works like a dream. The Sprint would hugely benefit from a full exhaust system (it currently has a modded one) so we've given them a Milltek to play with
I'd post up maps but I've bust my pc
Posted 11 November 2003 - 10:40 PM
Posted 11 November 2003 - 10:52 PM
Posted 11 November 2003 - 11:06 PM
