Spings Once Again
2 replies to this topic
#1 Dave
Dave
  • 3,679 posts
Posted 01 October 2006 - 01:12 PM
I really need to get my suspension sorted and found this on the Eibach website.
I didnt know they were doing Turbo springs....has anyone fitted these? or is it a typo on the website?
Any thoughts?
(I have emailed them to clarify)
Dave
Eibach Pro-kit springs
VX220 / Opel Speedster
[10-65-008-01-22] £203.57 £183.22
Eibach Pro-Kit springs for model: VX220 / Speedster, model variants: 2.0 Turbo, 2.2 16V.
Model years: (mm/yy): 09.00 -
Axle load, front: 450 kg
Axle load, rear: 700 kg
Lowering, front: 25 mm
Lowering, rear: 25 mm
Eibach part number: 10-65-008-01-22
The Eibach Pro-Kit spring system is the first choice for enthusiasts when upgrading their vehicle's suspension, improving both the vehicle's performance and appearance. Eibach Pro-Kit is designed to safely lower your vehicle, giving it a more attractive, sportier stance.
The Eibach lowering kit for Vauxhall Opel VX220 / Speedster are designed by experienced engineers specialized in chassis dynamics and are tested by seasoned qualified drivers. They are designed to properly and safely lower your car's centre of gravity through the use of proprietary progressive spring rates reducing squat during acceleration, body roll in the turns, and nose dive under braking.
With Eibach Pro-Kit your car becomes exceptionally stable and secure under a much wider range of conditions and will provide years of enhanced driving pleasure, whether you are twisting your way through a mountain pass or cruising down the motorway.
Advantages of Eibach lowering springs for Vauxhall Opel VX220 / Speedster:
Excellent ride quality - comfortable in cruising
Sporty handling in cornering, resulting in improved performance
Lowered center of gravity, increased stability
Enhanced appearance of vehicle
Manufactured according to ISO 9001 quality system as well as T?V approved
10 year product warranty
#2 colgy
colgy
  • 601 posts
  • Interests:Cars, women, beer (in that order!)
    Lying in bed, eating, fixing my godamn car!
Posted 01 October 2006 - 02:38 PM
Hmmm.....i hope its not a misprint, but I think it probably is! Axle loads and part numbers are the same as here, which is (meant) for the 2.2l. Keep us posted though! :)
EDIT: According to christurbo, NA springs wouldn't physically fit on a turbo damper, if you were thinking of going down the NA route it would have to springs and dampers.
Edited by colgy, 01 October 2006 - 03:00 PM.
#3 Dave
Dave
  • 3,679 posts
Posted 01 October 2006 - 04:25 PM
had a reply
Hello Dave
These springs are not suitable for the VX220 turbo.
I have corrected the error on our website - thanks for bringing it to our attention.
Regards
John
Edison Ltd Support Desk
www.edisonsupport.com
so ill have to wait for Thorney's springs
