Edited by mainline, 03 October 2006 - 09:52 AM.
Posted 03 October 2006 - 09:50 AM
Posted 03 October 2006 - 11:06 AM
I fitted these last week, great mod, my door doesn't rattle any more, it shuts with a thud, the shutlines look even on both sides. One problem though. I can't open the fcuking doors any more!
Well, not quite, but it takes a lot of effort, very stiff, seems to stick a bit, i've adjusted and adjusted and added washers, removed washers, greased everything etc. Its obviously to do with the 'snug' fit of the new pin around the lock, which is the whole point I suppose, but even with the lock button fully depressed its a right pain to open the doors.
Any advice!? Will it loosen with a bit of time?
Posted 03 October 2006 - 11:16 AM
Posted 03 October 2006 - 11:43 AM
As you have found the degree the pin protrudes is determined by the number of washers. But also where the nut fits, that pocket can also move in an X and Y direction. X is the closeness of fit for shutting and latch action ( nice kerthunk sound ) and tightness of door ( and window) to the door and roof seals. Y is for the height of the pin so that it does not hit the latch plastic surround and also to stop the door drooping.
The X and Y can be adjusted by slightly slackening off , and dragging the pin via very small amount up/down or left/right.
Posted 03 October 2006 - 07:46 PM
Edited by MrSimba, 03 October 2006 - 07:49 PM.
Posted 03 October 2006 - 08:15 PM
Posted 03 October 2006 - 08:55 PM
Edited by MrSimba, 03 October 2006 - 08:57 PM.
Posted 24 November 2006 - 04:21 PM
Posted 24 November 2006 - 05:45 PM
Posted 25 November 2006 - 06:33 PM
Yes!Will it loosen with a bit of time?
Posted 26 November 2006 - 09:22 AM
Edited by robkindred, 26 November 2006 - 09:22 AM.
Posted 27 November 2006 - 06:09 PM
Posted 27 May 2007 - 07:10 PM
Posted 27 May 2007 - 07:20 PM
There was a guy selling them on eBay, but I think he ran out of his initial batch and didn't make any more - certainly not seen them for sale for a few months, and I remember getting the last set of a batch he said would be his last.where do you get these pins from?
Edited by snoopstah, 27 May 2007 - 07:22 PM.
Posted 27 May 2007 - 07:26 PM
Edited by mandarinvx, 27 May 2007 - 07:26 PM.
Posted 27 May 2007 - 07:27 PM
Posted 27 May 2007 - 08:06 PM
Edited by Sutol, 27 May 2007 - 08:13 PM.
Posted 27 May 2007 - 09:28 PM
Yup - in fact it might be worth doing a search for Elise door pins on eBay as well as VX220 door pins.are the lotus ones the same for the VX though???
Posted 27 May 2007 - 09:31 PM
Posted 28 May 2007 - 07:31 AM
