Removing The Fuel Cap Surround...
15 replies to this topic
#1 kjmac
kjmac
  • 184 posts
  • Interests:Computers, Cars, the usual.
Posted 04 October 2006 - 12:59 PM
Okay, so I've removed all of the bolts - but the fuel cap surround seems quite happy where it is! Is it glued on as well, it is it just the fact that it's not been moved in five years? Anyone else replaced theirs? Ken
#2 salopian
salopian
  • 1,198 posts
Posted 04 October 2006 - 01:01 PM
Good question. Be interested to hear the answer to this.
#3 Astranomical102
Astranomical102
  • 614 posts
Posted 04 October 2006 - 01:50 PM
There is a thin cork shim between the filler cap assembly and the bodywork, years of dirt and grime ingress make it tricky to remove, to remove gently pry away from the body using a credit card or similar. Take care not to dislodge the cottage cheese type material behind the body as this can make reassembly quite tricky! :blink: Good luck, Craig.
#4 danuk
danuk
  • 162 posts
  • Interests:.
Posted 04 October 2006 - 05:06 PM
How did you remove the bolts, what do they bolt into, I tried to remove mine but gave up at loosening two of them as they just spin in their holes. so i didnt want to try any more. Dan.
#5 Dave
Dave
  • 3,679 posts
Posted 04 October 2006 - 05:24 PM
swapped mine for the VXR one a while back. The bolts came out fine.......but the filler surround needed some careful persuasion...I used a very fine flated headed screwdriver wrapped in some cloth and worked my way around very slowly/carefully. I thought it might have been stuck on but as said before it was the gasket stuck to the surround and bodywork. Good luck
Edited by Dave, 04 October 2006 - 05:25 PM.
#6 Astranomical102
Astranomical102
  • 614 posts
Posted 04 October 2006 - 05:47 PM
Quote "How did you remove the bolts, what do they bolt into, I tried to remove mine but gave up at loosening two of them as they just spin in their holes. so i didnt want to try any more." Like i said "cottage cheese". Its a peice of very soft plastic. the bad news is, its pretty much ruined if the threads have been stripped. The bolts in the "spinning holes" should just pull out with long nosed pliers. Hope this helps.
#7 kjmac
kjmac
  • 184 posts
Posted 04 October 2006 - 07:14 PM
Thanks for all the replies chaps! I've done it now, took about 25mins all in all. I knew one end of the cottage cheese bit was knackered, from when I replaced rusty bolts previously, but fortunately its in such a position that I was able to reach around the back and stick a nut onto the bolt. As far as removing the surround, I used my trusty mastercard to slowly pry the surround away, once wedged in, I then increased the wedge by throwing my switch card in there too on top of the mastercard. If you do that and work in circles around the surround it'll soon loosen. No sign of any glue, just years of gunk holding it I guess. Anyhow, I've now got a nice new cap and surround fitted to replace my horridly corroded ones. thumbsup thumbsup thumbsup Ken
#8 urbanmac
urbanmac
  • 951 posts
Posted 04 October 2006 - 08:06 PM
Good luck
is the VXR one black?
#9 Astranomical102
Astranomical102
  • 614 posts
Posted 04 October 2006 - 08:08 PM
*Ding* :D
#10 danuk
danuk
  • 162 posts
  • Interests:.
Posted 04 October 2006 - 09:07 PM
how to you get to the back of it...through the engien bay?
#11 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 04 October 2006 - 09:35 PM
Yep, up through the engine bay,
I'm planning to do mine soon when I can find a decent local anodisers :unsure:
The VXR is stupid money!
#12 kjmac
kjmac
  • 184 posts
Posted 04 October 2006 - 10:42 PM
Yep, it's just about possible to feel the back of the bolts if you stick your arm thru from the engine bay - long arms a bonus. K
#13 Dave
Dave
  • 3,679 posts
Posted 05 October 2006 - 07:22 AM
Good luck [/quote] is the VXR one black? [/quote] yep both surround and filler cap are black.
#14 danVXT
danVXT
  • 1,404 posts
  • Interests:Cars / Gadgets / Gym
Posted 05 October 2006 - 07:34 AM
i got mine done a few days ago, no silver at all left on my car now as they done the front griffing at the same time, alos had to get rear wheel re-sprayed due to some stone chips when i done a 180 on country road a few months back! The garage (alladin) have done a very good job thumbsup
#15 SteveA
SteveA
  • 9,158 posts
Posted 30 October 2006 - 06:43 PM
The Filler cap (93184415) is £49 from VXL and the surround (93184417) is £97! :o
#16 mandarinvx
mandarinvx
  • 12,621 posts
Posted 30 October 2006 - 06:49 PM
Yep, classic Vaux pricing :angry: , if only I had a lathe :rolleyes:
Should only cost about a tenner to anodise your existing one - I still haven't found the time to get mine done tho :huh: and not really possible if it's used as an everyday car :wacko:
