Above Exhaust Pipe Heat Shield
Posted 03 December 2006 - 01:01 PM
Posted 04 December 2006 - 09:04 AM
Posted 04 December 2006 - 03:26 PM
Edited by Mustang, 04 December 2006 - 03:30 PM.
Posted 04 December 2006 - 04:30 PM
Posted 04 December 2006 - 08:24 PM
Martin
I mean the moon shaped thing that fixes on to the rear mesh directly above the tail pipes. The bit that effectively protects your number plate from melting. Do you have one of those?
PE12- That's only about 20 mins from me, so would be perfect.
Posted 05 December 2006 - 09:42 AM
Posted 05 December 2006 - 02:27 PM
Posted 05 December 2006 - 04:40 PM
Posted 05 December 2006 - 05:03 PM
That's what I've just done as mine had come loose. Can the original be glued back and if so with what?easiest and cheapest solution is some hear resistant pipe from halfords cut to size for the gap, slit along one edge and slipped on to the mesh that is left,
Posted 05 December 2006 - 06:05 PM
Mine came off after exhaust bracket broke and exhaust whacked it. I still have mine though. Been told that only way to reattach is to bond it on. The heatshield does have a weld-like bit of bonding with bits of the mesh still on it so I will have to grind that off before thinking about re-attaching it. Think I may go the Crimson Killa method.....
Posted 06 December 2006 - 02:47 PM
I dont think you can just bond it back on (due to heat etc). I lost mine down a lane somewhere so not really sure about that one though.
From what I found out about it. Mine came off under warantee and vauxhall said its not really needed so they wont pay for a new on (about £300 btw inc fitting) the reason for the high fitting cost is that they have to remove the rear clam to refit it (it includes the mesh at the back ready constructed)
the cheap solution is as above and has helped not melt my number plate even though poxhall said its not needed.
Posted 06 December 2006 - 03:11 PM
Posted 06 December 2006 - 03:26 PM
pipemod
Posted 06 December 2006 - 03:29 PM
Posted 06 December 2006 - 05:31 PM
Edited by VIX, 06 December 2006 - 05:31 PM.
Posted 06 December 2006 - 10:27 PM
I had thought it was just the bit you could see when attached to grille but it does extend a few inches under the clam so is obviously designed to protect something....
grrr.. spent ages trying to resize the photos that I had posted.....
Edited by XXX, 06 December 2006 - 11:23 PM.
