Squeeky Sound? Any Help
10 replies to this topic
#1 Bujon
Bujon
  • 15 posts
Posted 15 January 2007 - 05:12 PM
Can anyone help me here with any ideas? My VX squeeks like mad only when I turn right at about 20% lock. The noise appears to come from the centre of the dash but from behond the the footwell. It sounds like someone rubbing polystyrene together and is driving me mad. :beat: It occassionally does it when breaking too. I've checked the suspension coils, and lubed all the bushes but to no avail, and have decided it's more a cosmetic problem rather than a mechanical indherence. Is there a bush at the base of the steering column?
#2 Shep
Shep
  • 802 posts
Posted 15 January 2007 - 05:20 PM
Mine made the same horrible squeaking polystyrene noise! Eventually got rid of it by replacing the steering rack (there was excessive play as well though) I lubricated it like crazy trying to get rid of that noise but it always came back. Sorry not much help really. :(
#3 Bujon
Bujon
  • 15 posts
Posted 15 January 2007 - 05:23 PM
What was the damage for a new steering rack? It's sounds like it might be the same problem. I do notice the noise stops momentarily if the car has been jacked up, which is while I thought it may be something and nothing as it reappears when the car settles back into shape.
#4 Scotsdave
Scotsdave
  • 761 posts
  • Interests:Muff diving
Posted 15 January 2007 - 06:55 PM
I'm in the process of replacing my steering rack and have done a little research in to it. The steering rack was made by a company called Titan Motorsport. The rack will cost £550 direct from vauxhall. Plans motorsport will sell you a recon rack for £220 +vat + your old rack. Titan Motorsport will sell you a brand new rack for £200 or they will recon your old rack for you and post it back. They quoted an hours labour to recon the rack and they charge £35 per hour + parts and postage back if your not local. I'm guessing it will cost just over £110 for my recon from Titan as postage to them was £18.50 alone. There are alot of of reconditioning companies out there but I choose Titan as they designed the rack so should know what there doing it. Play in the steering rack seems to be a common problem and a rattle over uneven ground is normally a good indication of the play. Not a good start for me owning the car but one of those things I guess. It took me an hour to remove the rack and putting it back on shouldn't take much longer. To remove the rack you need to disconnect the track rod ends, remove 4 bolts under the dash and then disconnect the intermediate shaft on the steering column it then twists and slides out a box section in the chassis. I hope this helps. Davie chinky chinky
#5 Guy182
Guy182
  • 4,459 posts
Posted 15 January 2007 - 06:59 PM
im getting worried... ive had what i think is the same squeeking before :(:(
#6 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 14 February 2013 - 08:45 PM
Holy thread resurrection Batman! :o I hit a pothole last night at about 20mph, getting the same squeaking sound from behind the passenger footwelldash when turning the wheel. Have I broken my steering rack? There doesn't seem to be any excessive play and the car still feels tight enough. I'll have a look after work tomorrow, any tips/pointers for things to check?
#7 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
Posted 15 February 2013 - 08:29 PM
Well, I put off leaving work sharp this afternoon :lol: When I eventually got home I had a proper listen, it was definitely coming from the rack. I jacked the front up, took the NSF wheel off and run the steering back and forth, had a general poke about, definate squeak there. Noticed my tyres have taken a mullering in the past few months, spotted a few other niggles while I was poking around making a list of things to fit for preventative maintenance, I just seen pound signs after factoring in a new rack. Disheartened and in a foul mood I stuck the wheel back on, put the car on the deck, took the roof off and went out a spirited drive. No squeak! It will probably re appear at somepoint, but it has gone for now, happy days :)
#8 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 15 February 2013 - 08:34 PM
If it starts squicking best pm ibob :ninja:
#9 TheHood
TheHood
  • 1,036 posts
Posted 15 February 2013 - 08:45 PM
My steering used to squeak when I turned the wheel especially in cold weather. For years I thought it was something to do with the cheapo plastics on the steering wheel and binnacle rubbing against each other. But when I was stuck in the foot well doing some wiring I noticed the metal steering column tube passes through a rubber grommet in the bulk head. A three second squirt of silicon spray on said grommet stopped 5+ years of annoyance :D
#10 N.E.M.O
N.E.M.O
  • 792 posts
Posted 15 February 2013 - 08:55 PM
Mines just started the same squeak! So so so annoying >:[
#11 TheHood
TheHood
  • 1,036 posts
Posted 15 February 2013 - 09:07 PM
Job done thumbsup
