N/a Oil Cooler
Posted 23 January 2007 - 07:39 AM
Posted 23 January 2007 - 09:20 AM
Posted 23 January 2007 - 09:22 AM
Posted 23 January 2007 - 12:01 PM
Posted 23 January 2007 - 12:26 PM
Edited by Winstar, 23 January 2007 - 12:28 PM.
Posted 23 January 2007 - 01:03 PM
Posted 23 January 2007 - 02:20 PM
Posted 23 January 2007 - 09:11 PM
The watercooled one is just fine for day to day stuff then, must just help to drop a few
degrees without cooling the oil too far
I can't see any benefits moving to air cooled, unless i was constantly tracking the car
Altho an aircooled setup is quite cheap......
A water-oil heat exchanger is very efficient. The Setrab unit fitted to the N/A is not very big though, but a bigger MOCAL laminova unit could be fitted without problems.
BTW The OEM take off from the oil filter housing has a thermostat built in because the cooler is on the rad return side.
For an air-oil cooler to work well in a mid-engined setup tou need to fit the cooler under the radiator in the nose of the car and that means running loooooong hoses to the front and back. Lotus do that on the S1 Exiges and now on the 111R and Exige2. Fragile setup though and the pressure drop across the long lines is questionable.
Biggest single advantage of a water/oil exchanger is that it is not dependant on the movement of the car to cool the oil, so it helps a great deal to dissipate heat from the oil on a cooldown lap and while the car is idling a littl while to cool down. (coolant has very big heat capacity and the normal fan to cool it down while standing still or moving slowly)
Posted 23 January 2007 - 09:23 PM
Posted 23 January 2007 - 10:38 PM
I thought there must be some kind of thermostat there, because as i said - whats the point of transferring the heat of the water to the oil!!!! but that explains it well.
but it mustve been designed like that for a reason
There's no stat on the oil side of the system, but due to the location of the oil cooler then the flow won't start going through the oil cooler until the rad circuit opens up at 87 deg c, before this the coolant circulates around the engine circuit only, so by that point the oil temp should be above the temp of the coolant.
Rob
Edited by Winstar, 23 January 2007 - 10:39 PM.
