Any Suggestions To Reducing Induction Kit Noise
Posted 07 November 2003 - 01:16 PM
Posted 07 November 2003 - 01:39 PM
Posted 07 November 2003 - 01:56 PM
Edited by garyk220, 07 November 2003 - 01:57 PM.
Posted 07 November 2003 - 02:00 PM
Posted 07 November 2003 - 02:08 PM
I like your suggestion, however, I don't understand how a panel filter can provide similar benefits to the performance when the air pipe on the induction kit is placed into the direct firing line in the side air intake (forcing cold air into the filter).I tried the BMC carbon dynamics airbox in mine (same as Ricky's) but took it back off for much the same reason. It sounded great on the 2.2, but the wastegate noise on the VXT makes it sounds like a Max Power RS Turbo
I've deristricted the standard airbox and fitted a Courtenay panel filter now (£30 if you do it yourself). The performance and induction noise are as good as with the induction kit, but the wastegate whoosing is more bearable now.
Just a query, not questioning your judgement.
cheers
Posted 07 November 2003 - 02:17 PM
Posted 07 November 2003 - 07:04 PM
Posted 07 November 2003 - 07:55 PM
Posted 10 November 2003 - 09:44 AM
Posted 11 November 2003 - 10:22 PM
The panel filter will be a little bit less restrictive than the paper element. Its the deresricting the airbox that helps power.Most engines suck air. The ram effect from induction kits is mostly marketing IMO. The standard airbox has 2 plastic restrictors, reducing airflow and more improtantly, drive-by noise. Removing these is easy and as well as allowing more air through, it staightens the path for the air flow too. The same mod on my 2.2 gave a huge benefit in the mid-range.
Admittedly, my opinion of the effect is subjective, but I'm happy that this mod will cope with standard and mild remaps (St 1 & 2). It might become restrictive with the full monty (Sprint or Regal mods) but by then, wastegate noise will be the least of your worries
Posted 13 November 2003 - 12:02 PM
Posted 13 November 2003 - 12:15 PM
You probably mean glassfibre tape. However, if you know of a source for asbestos tape please let me know. We can't get the stuff for love nor money.Wrap the outside of the induction filter and cloth duct with asbestos tape.
