Pagid Rs14 Bedding In.
Posted 13 March 2007 - 02:14 PM
Posted 13 March 2007 - 03:12 PM
Posted 13 March 2007 - 05:34 PM
Had Pagids RS14 fitted yesterday and bedded them in as it says in this link
I thought i was going to go though the window on the first one
It did give me a headache tho
One of the back brakes were squealling driving in to work this morning but only after beening stuck in traffic for 30mins
Oh and very light braking make harder and no noise
Edited by c18gmr, 13 March 2007 - 05:36 PM.
Posted 13 March 2007 - 09:00 PM
Posted 13 March 2007 - 10:14 PM
Posted 13 March 2007 - 10:31 PM
Pagid bedding in
That's exactly how I bedded mine in too (late at night
After some track work then road use, squealing appeared and drove me crazy when cruising.
However, worst part was that the Pagids overheat the stock N/A discs too easily in hard track use – needs cooling ducts
Posted 13 March 2007 - 11:50 PM
Posted 14 March 2007 - 12:17 AM
Brake to a standstill from 180 KPH (110mph)!!
Great idea when I live in the centre of York!!!
Oh well, late night drive for me then!!!
I dont think its says stand still 110mph to 50mph.
well i did mine yesterday the focus ST in front must thought i'd gone mad
Posted 14 March 2007 - 01:08 AM
Posted 14 March 2007 - 02:48 AM
However, will "track use only" pads invalidate your insurance should it ever come to light?
Can of worms time....
This has been discussed on here quite a bit in the past. In summary, iirc..... brake pads have to be 'E' marked to show they meet the relevant European standard. (As an aside this came about because of an incident a few years ago where cheap OEM brake pads were found to be made from compressed chicken litter...... seriously
To elaborate on the above, just found this in an old email from the Gits (Plans Motorsport)
Some facts on brake pads...
Regulation 90 (EC Directive) states that a pad has to be within 15% of the spec of original equipment item. This was to prevent motor factors selling sub-standard pads. RS14s are a ceramic pads and therefore outside this tolerance. The Mintex 1144 do have an R90 number. Ferodo DS2500 do not.
The RS14s are supplied by Vauxhall (although not fitted) and fitted by Lotus (although with stickers saying "not for road use").
HTH
Posted 14 March 2007 - 03:00 AM
Posted 14 March 2007 - 03:23 AM
http://www.vx220.org...8&hl=Pagid RS42
Pagid RS42 would appear to be a possibility if you want better stopping power than Mintex but less squeal? Never tried them myself though so YMMV.
Posted 14 March 2007 - 03:40 AM
Posted 14 March 2007 - 10:28 PM
Are these Ferodo pads both squeal bastards AND road-illegal AND grey-area-insurance-wise????? This would be a serious stopper for me.
Must admit that was a surprise to me too - from my discussions with John he said that the AP 4 pots come with the Ferodo's precisely bacause the RS14's are track use only. I used the Ferodo's for a while after I had the 4 pots on and they didn't squeal for me - but the stopping power is not up to RS14 levels, (but still much better than stock). At the end of the day if you're fitting 4-pots you should be telling your insurance company anyway - if you tell them about the pads and they Ok them then there's no problem
I'm using RS42's on the front at the moment - they do still squeal (at low speeds). IMHO, their ultimate stopping power is not as good as the 14's but 'feel' is improved (has been useful in the wet this winter) and wear rates (both pad & disc) are a lot better than 14's or 15's
Posted 28 March 2007 - 03:14 PM
Posted 28 March 2007 - 03:47 PM
