What Should The Air Intake Temp Be?
6 replies to this topic
#1 vxr36
vxr36
  • 1,179 posts
Posted 23 March 2007 - 01:32 PM
Lokking for some tech advice please. I am watching my temp guage vary dramatically. I suspect it is faulty but I would like to know roughly what it should be reading. I have a charge cooler fitted and the probe is right above the manifold. Some days it reads just above ambient (eg 6 to 17 degrees) Other days like today it was around the 60 to 70 mark. One day it went to 230 degrees.
#2 Jive
Jive
  • 361 posts
Posted 23 March 2007 - 02:01 PM
You need to speek to the people that fitted the cc. Around 60-70 degrees if i had to guess, maybe a little lower as you have a charge cooler something like 45-50. Im not sure really. All the same it sholud not vary like it does so it needs looking at. call the installer.
#3 ratboiler
ratboiler
  • 1,340 posts
Posted 23 March 2007 - 06:00 PM
Charge cooler fitted to my VXR temp gauge reads 98C most of the time.
#4 garyk220
garyk220
  • 3,035 posts
Posted 23 March 2007 - 06:25 PM
Should be around ambient air temperature when driving normally (perhaps a couple of degrees higher). Accelerating hard for 5 to 10 seconds would see the intake temp rise to between 40 and 55 degrees C, depending on how efficient your CC set-up is. Peak intake temp I've seen without the CC is 87 degrees C but that was when stationary at a hillclimb event, so no airflow through the IC. On track after 6 or 7 laps the temp hovers around 50 to 65 degrees C, and drops back to ambient very quickly as soon as I coast into the paddock. Your best bet is to find someone with an OBD reader or tuner/dealer with Tech2, to check the intake temp direct from the ECU and compare this with your gauge.
#5 vxr36
vxr36
  • 1,179 posts
Posted 24 March 2007 - 01:48 AM
Thanks Yep, I think it needs sorting out. It may be a fluke but it seems to go hay wire the morning after it rains :unsure: 24 hours after rain and when dry it reads just above ambient under normal conditions. Perhaps there is moisture getting in somewhere.
Edited by vxr36, 24 March 2007 - 01:49 AM.
#6 johnaachen
johnaachen
  • 2,619 posts
  • Interests:Karting, F1, golf, tennis, binge drinking, giving up smoking
Posted 24 March 2007 - 02:31 AM
On one of the trucks we are testing we use this temperture as an estimate of ambient air temperature. It generally reads about 10-15 degC higher than ambient under very low boost. Best way to check is probably on overrun i.e. no boost and just air coming through...this should be < 10-15 degC outside air temp. 230degC is definitely wrong....sounds like that is getting shorted to GND somewhere and giving a full scale reading. :borg: HTH :) garyk220 thumbsup
#7 Alex Os
Alex Os
  • 155 posts
Posted 24 March 2007 - 04:22 AM
If that reading is anything like correct i would stop driving it straight away otherwise i think you will knacker it. Unless its out of water i would suspect your gauge is faulty.
