Currently Getting Eml On - Error P1200 Injector Control Circuit
Posted 14 April 2007 - 05:18 PM
Posted 14 April 2007 - 05:50 PM
Posted 14 April 2007 - 05:53 PM
Posted 14 April 2007 - 06:07 PM
Posted 14 April 2007 - 06:14 PM
Posted 14 April 2007 - 06:19 PM
Posted 14 April 2007 - 10:05 PM
I reset the error with elm 232 and it hasn't come back on after 60 miles
Posted 14 April 2007 - 11:30 PM
Posted 15 April 2007 - 01:23 PM
C3F03
C3811
P3716
P1200
Intresting. the C codes should be chassis codes afaik and the P codes powertrain. I think the only chassis component that can report codes is the ABS system. But I couldn't find the codes you mentioned. Same goes for the powertrain codes. The codes relating to an injector circuit malfunction (is the closest I could find compared to the "error p1200 injector control circuit") should be p0201 - p0204 for each of the cylinders.
Bit strange, usually you should be able to match the codes to what is documented in TIS...
Mark
Posted 18 June 2007 - 10:24 PM
Posted 20 June 2007 - 08:21 AM
DTC P1137 HO2S Bank 1 Sensor 2 Lean System or Low Voltage
it appears in the TIS - http://www.speedster...el-Vauxhall.pdf
P1137 - O2 sensor power enrichment lean (Bank 1 Sensor 2)
The control unit recognises the malfunction of the circuit via an internal
evaluation logic.
Concerned Terminals:
X22: 51, 52
Refer to test step :C-21
What does this mean? I am an uber n00b at this engine stuff
Posted 20 June 2007 - 09:24 AM
Posted 20 June 2007 - 09:34 AM
which sensor is Bank 1 Sensor 2 ? the one before or after the main cat?
after main cat
Posted 20 June 2007 - 09:56 AM
Posted 20 June 2007 - 10:04 AM
I had this exact error the other week after a spiited drive, reset it using scantool and its a no show ever since.
hmm I've been getting it quite a lot (I think), now that I'm using scantool rather than digimoto I should be able to clarify it.
I also need to check what cat the car has, in fact I can't believe I didn't check when I had the undertray off during the rebuild
do you have a sport cat or the standard one?
Posted 20 June 2007 - 03:28 PM
a lean mixture can be caused by a faulty lambda sensor (before the cat), which is what was happening on mine.
this one
Edited by vocky, 20 June 2007 - 03:30 PM.
Posted 21 June 2007 - 08:33 AM
I also need to check what cat the car has, in fact I can't believe I didn't check when I had the undertray off during the rebuild![]()
I have the standard cat no precat and a VSE
My eml came on again last night after i went for a longer drive than usual. I suspect same error but havent plugged in yet, if it is I think I am goind to replace the O2 Sensors.
Edited by jimmymac, 21 June 2007 - 08:34 AM.
Posted 21 June 2007 - 09:08 AM
http://cgi.ebay.co.u...:MEWN:IT&ih=015
