Bonnet Grill Replacement.... Easy?
7 replies to this topic
#1 robkindred
robkindred
  • 370 posts
Posted 15 April 2007 - 07:00 PM
My drivers side bonnet grill is dented so I want to replace it. Vauxhall do the grill for £40. Which is fair enough.... but how easy is it to change it? Is it a case of cutting it out with a knife... cleaning up all the left over mastic and then re-doing it with new mastic stuff which vauxhall can supply?
#2 danyeates
danyeates
  • 3,246 posts
Posted 15 April 2007 - 07:02 PM
Yeah, it's just glued in, shouldn't be that hard to do. The glue is flexible and can be cut off. The glue Vauxhall supply comes in big tubes and I think costs around £30-40. Comes with a primer too.
#3 Muncher
Muncher
  • 4,494 posts
Posted 15 April 2007 - 09:15 PM
The old glue, which is something like Tiger seal is a right pain in the backside to get off!
#4 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 16 April 2007 - 02:52 AM
Some chav decided to use mine as 'goal' practice a few years back.... I used two pieces of wood and gentle hammering to straighten it out. Hardly noticeable now thumbsup
#5 robfenn
robfenn
  • 1,955 posts
  • Interests:Sports, Photography, Travelling, Racing Cars.
Posted 16 April 2007 - 01:46 PM
Do you have a part number for the grills? One of mine is also dented, as if someone has sat on it!
#6 ianrm
ianrm
  • 11,097 posts
Posted 16 April 2007 - 02:06 PM
I would use jules's method and re shape them. Getting the old adhesive off can be done but is a PITA. Part nos are L/H 9197060 R/H 9197059
#7 robfenn
robfenn
  • 1,955 posts
Posted 16 April 2007 - 03:54 PM
Thanks Ian.
#8 oblomov
oblomov
    oblomov
  • 3,873 posts
  • Interests:Mumblers
Posted 16 April 2007 - 07:35 PM
You're not wrong there mate. :( An absolute barsteward to get off, long drawn out job with a stanley knife. Also had to completely cut/destroy the old grill to get it off, and then use a pair of long nosed pliers to peel the remaining grill out of the adhesive by twisting rather like opening a tin of sardines with the key. :beat: Mind you that was a front grill not bonnet.
Edited by oblomov, 16 April 2007 - 07:36 PM.
