Definitive Wheel/tyre Thread?
Posted 27 May 2007 - 10:21 AM
Posted 27 May 2007 - 11:07 AM
They're also quite hard to find, you end up buying the second-hand so they might be buckled/kerbed, and if you've got an NA you need to make sure they're heat-treated. Although I guess you could buy them from Vauxhall directly, but I think they're about 280 quid each.
Worth pointing out that all the options will reduce understeer/increase oversteer, as you're reducing the differential between front and rear tyre sizes. Also, if you have an NA, you could consider Spax instead of Nitrons - about 550 quid instead of 1000+ quid, and they're still leaps and bounds ahead of the stock shocks/springs, by all accounts.
Posted 27 May 2007 - 11:25 AM
Posted 27 May 2007 - 04:42 PM
Posted 28 May 2007 - 10:38 PM
Posted 28 May 2007 - 11:13 PM
Very very light - I held one at Plans, you can literally hold it on one fingerGreat thread and I'm avidly watching for more replies as I'm currently going through this dilema.
Out of interest why are the magnesium speedlines the ultimate over the TDs? And if they are better, what makes them a grand better?
Unfortunately not entirely practical, as any scratches/scuffs will react! (then again I don't take my Compomotives anywhere near curbs, and I'd keep even further away if I'd spent that much on rims
Posted 29 May 2007 - 07:08 AM
Posted 29 May 2007 - 07:40 AM
Posted 29 May 2007 - 07:49 AM
Edited by slindborg, 29 May 2007 - 07:51 AM.
Posted 29 May 2007 - 07:58 AM
Posted 29 May 2007 - 08:06 AM
Posted 29 May 2007 - 08:51 AM
205/40/17 on the front will cause the ABS to enter ice mode (do a search) more often than is ideal, especially if the front tyres are worn and the rear tyres are unworn (as that's when the rolling radius is most different). They also don't look great cosmetically, if that bothers you (they have that 'stretched tyre' look).thanks, what fronts would give the nearest diameter to the standard rears: 205/40/17?
205/45/17 would be ideal, but your tyre range is reduced accordingly (i.e. no R888 option, which you do get with 205/40/17s). You'd also probably have to run 5mm spacers (which you, or at least I, get away without needing with 205/40/17s).
Also, remember you should be comparing tyre sizes with the standard front tyres (175/55/17s), not with the rears, as that's what the ABS module is calibrated to - and there's a 1.6% size difference between the standard rears and fronts. This means that 205/40/17s are 4.6% out, 205/45/17s are 1.3% out, and 205/50/17s are 2.0% out.
Posted 29 May 2007 - 09:00 AM
Posted 29 May 2007 - 09:19 AM
Unfortunately I can't help with any of that, as I'm running 205/40/17s without spacers, even with the ABS problems (which are fine as long as you're used to it).sounds like 205/45/17 then. You're the second to have tried/lived with that combo successfully. Have you tried 235's rears?
On the 5mm spacers any particular source or just Demon T? Re bolts which are already prone to failure standard, have you fitted longer bolts to compensate for the spacers and increased bolt strength?
sorry for all the Qs
About the only thing I can say is that I don't feel the need for 235-width rears with the 205-width fronts - there is one downhill off-camber exit from a roundabout to a motorway slip-road where it can feel very slightly unsettled if you're really shifting, but otherwise it's a very neutral drive - and to be honest I think it would feel unsettled regardless of the tyres, just because of the profile of the corner.
Edited by snoopstah, 29 May 2007 - 09:20 AM.
Posted 29 May 2007 - 04:58 PM
Posted 29 May 2007 - 05:36 PM
in our world there is really very little need for mag wheels, unless you just want to add that wikkid line to your max powa spec sheet lol
Lol, I am not sure I agree with the Max Power spec sheet comment
I have the Plans Magnesium Alloy speedlines and I can honestly say they have been the best money I have spent on the car. I can't compare with TD's or any other wheels but the difference in feel and general plantedness on the road is fantastic. I can't stand switching back to OEM's (which i have currently as off to the alps in a few weeks). Whilst on the road general drive is much improved, on the track the difference is even further highlighted.
Yes they are expensive and at the time it was a bit of a snap decision (like most decisions I make while visiting plans
In addition I knew that in the future I would either be going for a VXR or keep my N/A and get it TB'd or S/C'd. Either way a set of wheels is a nice easily transferable mod dependent on what I ultimately decide to do. Which at the moment is keep the N/A and turn it into a track monster
I do love the look of them too
Posted 29 May 2007 - 05:48 PM
Posted 29 May 2007 - 05:53 PM
Posted 29 May 2007 - 05:57 PM
Posted 29 May 2007 - 06:01 PM
Quite possibly. TBH I've never looked into it, I just remember when the eibach ones were available that other people that were buying them were saying that they were the only options and there was a bit of a rush to get the last available sets.erm surely you can get the relevant ID coilover springs in the appropriate rate and length from the likes of tweeks to lower the car.... they arent that expensive either
